1997 Integra won't start
Old Nov 19, 2017 | 08:22 AM
GiboGSR's Avatar
Default 1997 Integra won't start
Ok 1st time here need help on starting car I checked battery I have 12v, I checked key switch I have 12v on Acc Key 1 key 2 and start, I have checked starter and it gets 12v starter is new and been checked, oem alarm system has been removed, plastic stopper have been replaced with bolts, and push start the car it will start, but when trying with the key I am not getting my car to start. What am I missing
thanks in advance
Old Nov 19, 2017 | 04:37 PM
tamboo's Avatar
10 Year Member
Default Re: 1997 Integra won't start
crank or no crank?
no crank = likely bad connection(s) at battery/starter/ground or time for solenoid rebuild kit:
https://www.ebay.com/itm/TOYOTA-STAR...ZZ-Lx3&vxp=mtr
crank no start = no spark or fuel suspects:
Honda Acura Essential Electrical Repair Website. Troubleshooting Main Relay, Coil, Igniter, etc.
Old Nov 19, 2017 | 05:33 PM
GiboGSR's Avatar
No crank, verified battery connection are good also checked Starter connection they are good (new starter) also verified good ground on starter
Old Nov 20, 2017 | 01:24 PM
thewrai6th's Avatar
There is a single small wire running to your starter solenoid, not the large cable running to the battery. Get a volt meter, check the voltage is 0 when you are NOT cranking. Have someone try to start the car, the voltage on the starter wire should be >= 12v. If the wire is getting power, it's your starter, or cable to the battery. The solenoids are crap on these starters, there are parts online just to fix the solenoid.
If the wire is not getting power, it is an electrical issue. Could be the main relay under driver side dash, ignition switch, ECU, or even low battery voltage or bad ground, just to name a few. You can verify the starter works by running power directly to the starter solenoid (this will turn the engine over, so be careful not to kill yourself). Put car in neutral, plug a wire into the solenoid and then touch it to positive.
Old Nov 21, 2017 | 07:33 AM
Red_Teg's Avatar
Make sure the copper rings that get bolted to the starter are completely clean on the ground and power cables. If it isnt completely clean it wont give the starter enough juice to spin the flywheel. This happened to me multiple times.
Old Nov 24, 2017 | 07:53 AM
GiboGSR's Avatar
thank you I looked at the starter and I didn't see a ground to it so I just placed jumper cables from battery to the starter and flipped the key and it worked. I have a 4 gauge ground from frame to the head, I am going to ground near the Block to see if that helps thanks again
Matt S.
Jan 31, 2016 11:24 AM
JJT211
Jun 22, 2014 08:33 PM
DIZSTRICTxB3A5T
Mar 11, 2011 12:41 PM
jimboek
Apr 26, 2007 07:12 PM
dingusjt
Jan 5, 2005 09:59 AM
