Am I screwed?
Old 04-20-2018, 09:22 AM
brenaj's Avatar
Default Am I screwed?
I finally got the motor in (B18C) and hooked up all the lines. When I started for the first time it immediately started leaking oil from the head. It seemed to be this oil line that goes from the back of the head to the back of the block. I unscrewed the bolt and come to find a crack. Is this bad?
As of right now I added new seal tape and gasket maker seal. Gonna let it dry for 24 hours. My only worry is that it’ll won’t work. Does anyone have any recommendations on how to fix it?
Old 04-20-2018, 11:41 AM
egsleepercivic's Avatar
Default Re: Am I screwed?
to me it looks dead, but you might be able to pull the head, have it welded and tapped
Old 04-20-2018, 03:28 PM
Fish Twig
tony_2018's Avatar
try welding it up and retap, jb weld maybe
Old 04-20-2018, 07:20 PM
brenaj's Avatar
yes a friend suggested jb weld. I’ve never heard of it before. I put some of it on and imma leave it for 24hours. Hopefully it works. If not, I guess I am screwed.
Old 04-20-2018, 07:25 PM
brenaj's Avatar
Old 04-20-2018, 07:45 PM
surfingsk8r's Avatar
So, is the bottom end an LS variant? (B18A/B or B20) If the block is a B18C then it should have provisions to send oil to the head internally and not require that feed line. Typically that is only used in LS/Vtec setups. My point is, if its a true B18C then you should be able to remove that line after ensuring that they head has not been plugged from normal oil flow and then just have that threaded hole welded shut. Either way the head has to come off to fix it properly.
Old 04-20-2018, 07:53 PM
brenaj's Avatar
Well the block says B18C and the head says P72-1. What would I be looking for to check the normal oil flow has not been plugged?
Old 04-21-2018, 09:43 AM
You would have to take the head off the block and look at the oil port that is on the bottom of it. If you read through these instructions regarding a LSVTEC conversion and kind of back track them you will see what I am referring to. How To build a Reliable LS VTEC - My Pro Street In particular pay attention to the part that says "Modify Your VTEC Cylinder Head"
Old 04-23-2018, 07:58 PM
Fish Twig
tony_2018's Avatar
i watch some youtube videos of jb weld use to fix some commercial boat parts, its interesting
Sr420Det
04-16-2011 02:55 PM
scspeed
04-18-2009 01:54 PM
RabbittZ
06-12-2007 05:58 PM
Nextelbuddy
05-05-2003 08:10 PM
Quick Reply: Am I screwed?
