Excessive egine vibration?
Old 06-19-2018, 08:41 PM
Kirt Thelander's Avatar
Default Excessive egine vibration?
I wanst sure where to ask this. But here I go
Quick background - Owned a 92 accord Accord for almost 3 years, f22b swap I did with pops, auto.
Just bought a 93 integra, manual.
More info -
While driving the accord I felt very little vibration from the Motor inside the car and more specifically the pedals. Compared to the Acura .
Question - Why do I feel more of a vibration with the Integra than I do the accord ?
Speculation - I think it's because the Acura is just less car so the vibration doesn't have as much mass to disapate through so you feel it alot more inside.
Or a loose motor mount?
Super loose valves? Although I don't here them ticking THAT loudly.
Cuz it's a stick ?
A combo of things?
Is it just normal?
Thanks again guys and gals
Old 06-20-2018, 11:21 AM
MotorMouth93's Avatar
Default Re: Excessive egine vibration?
I think worn motor mounts are most likely your culprit, how many miles? The other things you mentioned probably play a part as well, even with brand new motor mounts my 99 Integra would vibrate a bit at idle. Also the F-series has balance shafts so will be a bit smoother than a B-series.
Old 06-21-2018, 04:38 AM
CandyRedRC46's Avatar
Old/broken motor mounts, stiffer aftermarket mounts and/or engine running poory
Camaro6t9
08-22-2018 09:09 AM
kenp35
08-01-2018 12:56 AM
bigbpatel
01-24-2013 11:24 PM
Jas29
12-11-2011 04:11 AM
Quick Reply: Excessive egine vibration?
