Crank sensor? **Need help**
Re: Crank sensor? **Need help**
If the mounting points are the same and you have the star shaped crank timing gear, cause theres 2! one is just the gear teeth and other that has the star around the gear is for the crank signal pick up. and it plugs to the harness your using yes! most B series parts are interchangeable.
