Cel code 14, help please
Old Sep 10, 2018 | 12:53 AM
OgulcanTR's Avatar
Icon4 Cel code 14, help please
Hello, My 92 db1 integra (b18a2 engine, PR4 ecu) Cel code 14.
I changed 3 different IACV, cel code not deleted.
IACV cables are robust. What is the problem?
Old Sep 12, 2018 | 04:09 AM
K20.ek's Avatar
Default Re: Cel code 14, help please
Check your wiring could be swapped with knock sensor or coolant temp sensor
Old Sep 12, 2018 | 09:52 PM
OgulcanTR's Avatar
The B18A2 does not have a knock sensor, exactly what do i have to do?
Old Sep 13, 2018 | 04:19 PM
wunfstgsr's Avatar
Loved
Community Favorite
Do you have any issues starting up in the morning or at anytime?
Like mentioned above most likely you have the wrong plug in the IACV there's other sensor plugs that fit in the IACV, look around to see any other plugs near that might be switched, I also think the IAT sensor has the same style plug and can also reach the IACV so its possible you plugged the wrong plug in the IACV.
Old Sep 13, 2018 | 10:09 PM
OgulcanTR's Avatar
No problem when the engine is running, constant at 1000 rpm.
I'm sure the plug is correct, could the ECU be faulty?
terplaygroun_dc2
Oct 23, 2008 09:38 AM
ej2civic
Jan 7, 2007 11:24 AM
90jdmcrxdude
Feb 19, 2006 05:45 PM
GeeSeeR
Oct 14, 2001 11:07 AM
