High idle
Old May 2, 2018 | 04:05 AM
blakeasul's Avatar
Default High idle
Car has very bad idle when ever in park or n it goes up to 2000 rpm then after 30 sec it shoots up to 5000 rpm
Old May 2, 2018 | 12:07 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: High idle
vacuum leak
Old May 3, 2018 | 02:20 PM
Creator's Avatar
What rick_rabies said. You can get a can of throttle body cleaner or carb cleaner & spray it around the intake side of stuff/vacuum hoses while the car is running. If the engine stutters while doing so, you've found your leak.
Old May 3, 2018 | 07:41 PM
wunfstgsr's Avatar
Loved
Community Favorite
Check your PCV valve
bantum1cwa
Mar 5, 2014 06:25 AM
Space Cadet
Oct 19, 2010 05:01 PM
erichackett
10
Jul 27, 2010 06:43 PM
JDM-KIDD
Aug 4, 2009 05:22 AM
h22831
Jul 18, 2005 06:36 PM
