What spark plugs are you running?
I have a D16Y7 with Z6 head turbo. Vitara pistons, Eagle rods.
I haven't started the motor yet, looking to make 220-260whp anywhere in that range would please me.. What spark plugs do YOU guys run and what do you recommend for ME?
Re: What spark plugs are you running?
i only run non-resistors in the 8+ heat range because they dont really have any resistor plugs that cold
a .028" gap should be fine. you only need to go smaller if you are blowing out spark. a bigger gap will give the car a better idle. also the 4091 are non-resistor. i think he would be better off with regular 4644, bkr7e like everyone else recommended.
NGK iridium's are also like $10 a pop!! not to mention you cant gap them... well... you can... but chances are you will *** your iridium tip
