WTF WRONG MANIFOLD WHAT DO I DO NOW?
Old Aug 18, 2010 | 03:05 AM
area522010's Avatar
Icon2 WTF WRONG MANIFOLD WHAT DO I DO NOW?
I made the mistake of buying a ram horn manifold off a guy on here. and i failed and forget to ask what the flange size for the wastegate. but when i reread his post he stated it was a 38mm flange. i made the mistake of over looking that. what can i do its a custom manifold, is there a flange avail like a t3/t4 flange or do i have to buy another manifold. im trying to fit a 44mmwg..
Old Aug 18, 2010 | 03:20 AM
Autoworks's Avatar
Default Re: WTF WRONG MANIFOLD WHAT DO I DO NOW?
You can either cut the flange off and replace it w/ a 44mm flange or use a 38mm to 44mm adaptor flange
Old Aug 18, 2010 | 03:42 AM
area522010's Avatar
thanks i thought i had to buy another manifold
Old Aug 18, 2010 | 12:38 PM
SAXON's Avatar
just realize that the best option is to have it modified, the 44mm gate wont work as well with the adaptor
Old Aug 18, 2010 | 07:12 PM
TorganFM.'s Avatar
Angle grinder, hammer, have fun!
Old Aug 18, 2010 | 07:19 PM
area522010's Avatar
just had one made tonight will test tomorrow on buddies lsv boosted setup
Old Aug 19, 2010 | 03:18 AM
RickyLee53's Avatar
If the manifold has been used i'd be less inclined to take this option. Also remember the 44mm gate has a smaller valve seat than 44mm, (more like 41mm IIRC) and the pipe that will have been used will be 38mm, so theres not a massive difference.
Ulitmately it depends what turbo the op is running if he will get creep or not.
Old Aug 19, 2010 | 05:33 AM
91jdmhatchback's Avatar
Old Aug 19, 2010 | 06:22 AM
twkdCD595's Avatar
Take it from someone who used an adapter on my old manifold for a VERY short period of time, have someone weld on a 44mm flange. Adapters are a pita. For virtually the same money and less headache you can take it to someone to weld up a new flange.
Tippyman
Jul 4, 2013 07:22 PM
KdF
Sep 23, 2010 07:14 PM
nitroice40
Welding / Fabrication
Apr 6, 2006 03:11 PM
S2KP
Mar 11, 2003 07:04 AM
