-3an line with restrictor
Old Aug 23, 2010 | 05:02 PM
boosted2.4's Avatar
Default -3an line with restrictor
Ive got a new journal bearing 6765 with a -3an feed line. Once the car warms up I start getting oil smoke out my exhaust. My return is -10an with no 90's or kinks in it and its not lower than the oil level in the oil pan. I was wondering if it would be ok to add a .065 restrictor with an -3an feed.
Old Aug 23, 2010 | 05:06 PM
TheShodan's Avatar
Moderator
Default Re: -3an line with restrictor
possible. Give it a try at this point. its not too small. Check that oil pressure, and make sure the cartridge isn't clocked more than 20 degrees from vertical, or tilted back more than 10 degrees.
Old Aug 23, 2010 | 05:17 PM
boosted2.4's Avatar
Thanks I will try it. I wasn't sure it I needed to run a -4an feed if I was going to run a .065 restrictor. The cartridge is straight it is tilted a little but not more than 10 degrees.
Old Aug 23, 2010 | 05:52 PM
WhiteEJCoupe's Avatar
how many damn Precision turbos do this? this is an ongoing problem with them, glad im not the only one. i guess they are notorious for this.
Old Aug 23, 2010 | 06:05 PM
EsotericImage's Avatar
Retired Moderator
Seen a few threads pop up outta no where!
Old Aug 24, 2010 | 06:13 AM
per4mance's Avatar
run a restrictor
Old Aug 24, 2010 | 07:52 AM
twkdCD595's Avatar
Its not just Precision.
High oil pressures of a healthy honda motor tend to require a restrictor on many turbos as they exceed the max oil pressure the turbo is designed and rated for.
Old Aug 24, 2010 | 08:16 AM
Axix24's Avatar
these threads are popping out of nowhere... Maybe bad assembly of the turbos on the production line... i would ship it back and get a new one.. A properly seal turbo shouldnt smoke regardless of an restrictor espec when brand new..
Old Aug 24, 2010 | 08:26 AM
twkdCD595's Avatar
I am not sure where you got your information but thats not correct.
All turbos have a design limit and rated max oil pressure. Its not a made up number, its there for a reason. You exceed it you risk pushing oil, even on a brand new turbo.
Old Aug 24, 2010 | 11:56 AM
blackeg's Avatar
you can run the -3 with restrictor, thats what i use on my journal bearing turbo. also as the shodan said, check the clocking of the turbo, you want the feed and return as close to vertical as possible
Old Aug 24, 2010 | 01:01 PM
SpoolnG2's Avatar
Ive got a brand new bullseye S362 and its pushing oil passed the seals and into my intercooler. I have a -4 with no restrictor right now. What I will be changing to is a -4an with a .065 restrictor. It says on the ATPturbo website that a .065 restrictor is what should be used for Journal bearing turbos and larger ball bearing turbos.
Old Aug 24, 2010 | 07:04 PM
ken00si's Avatar
Had the same problem with my SC61 and had to switch from a -4an feed line to a -3an feed line with restrictor.
By the way, this is on a fresh motor rebuild. The car ran fine for 2 years and 1000 miles with the -4an feed line...go figure???
velisma
Jul 20, 2010 01:18 PM
PA MATT
Aug 19, 2004 06:12 PM
alfee
Jun 28, 2004 04:10 PM
redboost10
Oct 22, 2003 06:56 PM
808eg6
Jan 24, 2002 08:34 PM
