b16 head with skunk2 internals????
Old Aug 31, 2010 | 10:01 AM
tony_yang's Avatar
Default b16 head with skunk2 internals????
i have a question. i have this deal to buy a b16 head with skunk2 everything in the head. its ported and polished. the guy was going to use it for all motor ls-vtec, but when a different route. my setup is a b16 block boosting. my friend told me that i couldn't use the head due to the ports on the head. is that true? plz help.
Old Aug 31, 2010 | 10:32 AM
cleansi's Avatar
Default Re: b16 head with skunk2 internals????
there is no reason you can use it. pp will only help flow.
what stage and type of cams are they ?
pro series or tuner ? stage 1,2,3?
whats you compression and set up?
Old Aug 31, 2010 | 10:43 AM
tony_yang's Avatar
my setup is
Block-
eagle crank
eagle rods and bearings
je 9.5.1 compression
fully balances
darton block guard
bore to 84mm
stroke to 1.9,
Turbo-
Garrett t3/t4 60 trim
38mm wastegate (delta)
greddy b/v
Fuel-
aem fuel rail
aem fuel regulator
750cc injectors
3 bar map
i have a aftermarket fuel pump also,
Old Aug 31, 2010 | 10:45 AM
tony_yang's Avatar
im not sure what stage cams they are and what type. i was told its skunk2 everything.
Old Aug 31, 2010 | 11:05 AM
cleansi's Avatar
im not sure what skunk2 uses to identify the type of cams but i know it is a notch at the end of them on the dizzy side. i would highly recommend you check to find out exactly what cam shafts they are before you throw her together. stage 3 proseries and 9.5 compression are not the ideal set up for boost thats a big lift duaration.
im sure if you contacted sk2 or researched you could identify them
Old Aug 31, 2010 | 11:12 AM
kyden's Avatar
i would definitely make sure you know what cams are in there.
Old Aug 31, 2010 | 11:16 AM
90blackcrx's Avatar
Sounds like your friend doesn't know what he is talking about.
Old Aug 31, 2010 | 02:16 PM
tony_yang's Avatar
whats the differences between pro and tuner? from what i research, the stage 1 and 2 are the tuner camshafts and the pro are turbo 1 and 2 camshafts.
Old Aug 31, 2010 | 05:55 PM
cleansi's Avatar
tuner series was made for carb legal builds ie emissions they are less aggressive
*JDM*
Jun 19, 2009 04:09 PM
poormans_typer69
12
Jul 15, 2008 06:51 PM
punkracer
Oct 16, 2004 07:29 PM
1bad-eg
Jan 20, 2003 08:44 AM
