obd1 o2 simulation settings
Old Aug 21, 2010 | 06:03 PM
Spawne32's Avatar
Default obd1 o2 simulation settings
hey guys, im having some issues programming the narrow band simulation for a 95 integra with a 4 wire o2 sensor. I cant find what the values should be anywhere.
Old Aug 22, 2010 | 07:27 AM
sicones's Avatar
Default Re: obd1 o2 simulation settings
The analog output #1 factory defualt for the LC1 emulates a stock narrow band.
Old Aug 22, 2010 | 07:41 AM
Spawne32's Avatar
hmm alright then, i guess maybe it was the multiplier that was causing the problem, it seems it was programed to a custom fuel setting of 1700x for some reason, i had to program it back to gasoline. will have to check it out today. Theres no special settings for the rate at which it provides the information? or the warmup period? etc etc?
Old Aug 22, 2010 | 11:13 AM
Turbo Trip's Avatar
For an obd1 honda the exact factory setting from innovate will work fine - they are not terrible finicky or advanced.
Old Aug 23, 2010 | 03:29 PM
sicones's Avatar
There is a setting in the innovate software for sampling rate and stuff, under advanced. Not sure about heating time, that would be fixed from the factory. I heard from innovate when you unplug the serial cable from an XD16 guage it will screw up that exact setting that was off on yours.
B16beatdown
Oct 11, 2007 07:13 AM
ys1civicsi
Apr 2, 2007 04:35 PM
russianswty
Dec 29, 2006 04:30 PM
Junkyard2000
Nov 2, 2005 10:19 PM
