D16 Injectors
Old Aug 24, 2010 | 07:34 PM
93 Eg Couper's Avatar
Default D16 Injectors
I have a D16Z6 Intake mani and head on a Y7 block.
I am running RC550's.
First, I bored my O-ring seals (the big ones) that sit in the intake mani. Leaked a bit at the bottom but then i got new oem seals and RAMMED my injectors in. NOW, they **** fuel out the TOP where it meets the fuel rail, top o-rings are in place...WTF
Old Aug 24, 2010 | 08:11 PM
Default Re: D16 Injectors
Are they supposed to sit up, not fully in the large O-ring in the mani? I thought they were to be rammed in, squishing the O-ring...
Old Aug 25, 2010 | 01:37 AM
2kdrift's Avatar
got any pics?
your talkin about the rubber seal on the manifold rite? i dont know about rc's but my dsm's i drilled taht seal and the injectors sat down in about a half inch or so
Old Aug 25, 2010 | 05:24 AM
dpetro1's Avatar
The RC instructions tell you that the injectors should sit on top of the IM seals. so you should not bore them out. as for the top o-rings, they get pinched easily. i found it best to use OEM honda upper o-rings. they seem to be a bit smaller and go into the fuel rail without ripping. make sure to use some oil or grease to further help your install
Old Aug 25, 2010 | 05:25 AM
dpetro1's Avatar
RC instruction sheet attached
File Type: pdf
Ldo
Jun 27, 2010 04:55 PM
jarven93
Jan 12, 2007 10:20 AM
SiRay13
Oct 21, 2006 04:30 PM
RNPoo7
Sep 4, 2005 11:34 AM
JeremyL
Feb 26, 2003 05:24 AM
