500hp Daily with 8.4:1???
Old 08-24-2010, 04:54 AM
t00JDM's Avatar
Default 500hp Daily with 8.4:1???
Im looking to push about 500hp while at the same time have a reliable daily driver on this set up. Anyone have experience with this kind of compression and what power i should be making?
Fuel:
93 Pump
Head:
GSR head
CTR Cams
Skunk2 Springs
Skunk2 Retainers
Skunk2 Cam Gears
1000cc Injectors
AEM Fuel Rail
Hp Racing Intake Manifold
Type R Throttle body
Block:
B18c Gsr
Darton Sleeves .5 overbore
Ross 8.4:1 Pistons
Eagle H Beam rods
Billet Oil Pump
CTR Crank Pulley
Turbo Set Up:
Peakboost Ramhorn
Percison T/3 T/4 60 trim A/r.82
Turbosmart Wastegate
Greddy Blowoff
Old 08-24-2010, 05:34 AM
non-VTEC's Avatar
Default Re: 500hp Daily with 8.4:1???
you may need a different turbo to reach your power goal....
Old 08-24-2010, 06:10 AM
per4mance's Avatar
at that compression you will be luck to make 400 whp. This is not 96' you can run higher compression no days. If you don't want to change compression chagne turbo's, mayeb a 35r or one of the new billet 6262's
Old 08-24-2010, 06:43 AM
Kyle R's Avatar
I agree. You won't make 500hp on that turbo. Why do you want to run such low compression? That car is going to be a slug out of boost.
Old 08-24-2010, 07:09 AM
AlexDphoto's Avatar
Change your compression to the 9.x:1 area, high boost and E85 would be the best bet for 500whp, may even want to consider 10:1
Old 08-24-2010, 11:46 AM
tony413's Avatar
change turbos and leave the rest of the set-up, however im concerned that your cam choice is NOT going to work good or at with 8.4:1 compression perhaps you should contact bisimoto or raise your compression.
Old 08-24-2010, 11:54 AM
blackeg's Avatar
yeah, there is really no reason to have that low compression. anything in the mid 9's is more than fine. i also agree that you will need a larger turbo, as well as e85 or some high octane on pump local to you for the goals you have.
Old 08-24-2010, 04:50 PM
lunatics209's Avatar
I would go with E85 fuel. The billet precisions are what most people run now. The 6162 or 6262 will be most ideal. Please bump up that compression also. I wouldn't even consider 9.0:1 for a street turbo. I would start somewhere around 9.7:1-10.8:1. The higher compression really helps with your low end. Running a higher compression you will also achieve your horsepower goals with lesser boost.
Old 08-24-2010, 05:01 PM
DC4KiD's Avatar
Should be able to get really close to, if not reach, 500hp with that turbo, just not with 93 octane.
Old 08-24-2010, 05:55 PM
93supercoupe's Avatar
my roomate made 430 on a 60-1 and pump gas, cast mani and 272's in a 8.xto1 DSM
that was on 24-28lbs though
Old 08-24-2010, 06:17 PM
tony413's Avatar
not exactly a good comparison engine V.E. in honda is better and the head flow is also better.
Old 08-24-2010, 07:51 PM
t00JDM's Avatar
thanks for the info. i would love to run e85 which is how i got the car but it wouldnt be the most practical for daily driving...yea im going to use this turbo for the time being because its brand new....but i will definitely look into getting a bigger turbo.
Old 08-25-2010, 12:01 AM
I remember someone said that these are honda/acuras. Not DSM's. So do not treat them like a DSM.
Old 08-25-2010, 04:41 AM
blackeg's Avatar
i did that on my 2 liter motor, 18 psi though. i bought my current 60-1 for 300 bucks used 3000 miles in good condition. now i know they arent the best of technology, but they have been getting the job done for a long time and offer a cheaper alternative to newer turbos
your motor seems built enough, you could run in the 10:1 range.
and since you are sleeved, dont bother with 81.5mm, go up to 83 or 84mm. you will thank yourself when driving around town. i was very happy with the upgrade from 81 to 84mm when i did it a few years ago.
Old 08-25-2010, 05:27 AM
96 GSR-T's Avatar
You wont hit 500whp with that turbo....
LOL I guess this graph wasnt possible with an 81.5mm GSR stock cams @ 8.2:1 Compression....
Old 08-26-2010, 10:00 AM
t00JDM's Avatar
wut turbo are you running?
Old 08-26-2010, 10:13 AM
Moderator
TheShodan's Avatar
Ah.. there's the rub ... "what turbo.." indeed.
Old 08-26-2010, 07:07 PM
blackeg's Avatar
wut u tryin to say here lolz j/k.
Ok, not that you can't do 400hp on low compression, its just that there is no need to go that low...
Old 08-26-2010, 07:58 PM
tony413's Avatar
you totally do get it. we are no longer on the question of compression ratios but rather turbo size.
Old 08-26-2010, 08:33 PM
tasco's Avatar
Making the static CR lower creates a larger combustion chamber, and raises the ceiling on the amount of power you can make on a given fuel. It also dramatically lessens the volatility of the engine if it's operated close to where detonation will take place.
Old 08-26-2010, 09:01 PM
Moderator
TheShodan's Avatar
But the power made is still the same. given the same turbo, you can take an 8.5:1 motor, throw 20psi at it and make XX power. You can take a 9.5:1, use less boost and make the same power. ITs the difference between getting to effective compression that makes the compression ratios differently. But it doesn't make more power with lower, than with higher, unless that pressure ratio of that turbocharger is not efficient in that island.
Old 08-27-2010, 07:22 AM
tasco's Avatar
Taking power per psi, and psi out of the equatoin, which will make more overall power on say 93 octane before detenating 8.4 or 10.0?
Old 08-27-2010, 08:34 AM
tony413's Avatar
cfm is still an issue, but 8.4cr gives you more room to play around with timing events and be more aggresive on lower octanes. could you be aggressive on lower octanes with 10:1cr? yes, BUT your going to be running really rich and that in itself will create some problems.
Old 08-30-2010, 04:43 AM
96 GSR-T's Avatar
t3/t67h.o. dotted was 15psi with some boost creep and the solid line is 21-23psi using E85.... the motor carried that hp past 10k rpm.
Old 08-30-2010, 06:37 AM
hybrdthry911's Avatar
if the engine is already built run it. just get a bigger turbo. even with higher compression you would need a bigger turbo anyway. get rid of that CTR crank pulley though that is an oil pump killer. ive seen a couple b series oil pumps let go on the dyno because of this.
Quick Reply: 500hp Daily with 8.4:1???
