Re-welding open manifold to divided
Old Aug 19, 2010 | 09:25 AM
sflemon's Avatar
Default Re-welding open manifold to divided
Is it possible to re-weld a mild steel tubular manifold to make it a divided manifold? I have a very nice mild steel equal length manifold I'd like to have a welder to work on. Primarily add a piece of steel in the collector to divide the runners and weld on the proper divided flange.
Not 100% ideal, but I think it may be worth it if it can provide the desired results. And would be hella cheaper than a "quick spool" valve. Not sure I like the idea of that valve anyway.
Old Aug 19, 2010 | 09:32 AM
kyden's Avatar
Default Re: Re-welding open manifold to divided
what good is dividing it if the runner pairings don't match?
Old Aug 19, 2010 | 06:15 PM
sflemon's Avatar
They do pair properly already....
Right now I get 25psi at about 5000 rpm. Precision 6062 turbo. If it gets me 250 rpm of spool I'd be thrilled.
Blove1991
Dec 19, 2011 06:50 PM
lsvsol
May 14, 2006 06:35 AM
lkailburn
Welding / Fabrication
Jul 31, 2005 11:57 AM
Turbocivic94
Nov 2, 2004 08:18 AM
J2turbo21
Dec 26, 2002 06:24 PM
