How much boost can I run?
Old Sep 9, 2010 | 11:45 AM
civic2slo's Avatar
Default How much boost can I run?
I was wondering how much boost I can run out of a B16A 84mm with 10.5 to 1 comp. I can use a cometic headgasket to lower it 10 to 1. I know different size turbos and so on will affect my choices. If any one can give me a good combination as starting point it would be appreciated. Keep in mind it will be a street driven car not a drag car.
Plans are:
750 or 850cc inj.
57 to 60 trim turbo @ 15-20 psi. Maybe bigger dont really want lag though
Stock B16A head for now.
2 1/2" exhaust or 3" with a cut out to a 2 1/2" axle back
Old Sep 9, 2010 | 12:06 PM
boostedeg302's Avatar
Default Re: How much boost can I run?
search
Old Sep 9, 2010 | 01:24 PM
civic2slo's Avatar
I have search... But no definate max psi I can run. I want to see what other people are running and get an idea what direction I should go.
Old Sep 9, 2010 | 02:47 PM
EsotericImage's Avatar
Retired Moderator
why not leave that to the tuner.
Old Sep 9, 2010 | 02:51 PM
Glove's Avatar
i hear they say you can run about 20 psi on that
joe111599's Avatar
Stock b16 with 10:1...maybe 15-20ish psi on a 57 trim. Whatever it takes to get you 300-350whp. I wouldnt run much more then that personally. Goodluck.
Old Sep 9, 2010 | 02:53 PM
Retired Moderator
compare the compressor maps on the turbo's you want.. the one that stays in the efficiency range is the one you want.
Old Sep 9, 2010 | 03:54 PM
civic2slo's Avatar
The B16A is golden eagle sleeve to 84mm. Just wondering on max psi then go about 5 to 10 psi below that. Then I would decide on a turbo size and the rest of the setup.
Old Sep 9, 2010 | 07:07 PM
lsneo's Avatar
probably about 90psi
Old Sep 9, 2010 | 07:11 PM
megomaniac's Avatar
unless you can get e85, crank it up till it knocks or something bad happens , then turn it down a little, cross your finger's and hope for the best.
Old Sep 9, 2010 | 07:34 PM
civic2slo's Avatar
I guess I didn't explain it thoroughly. I'm trying to figure out what my max psi I can run. Then go 5-10 psi below that. Then I can decide on the turbo size, injectors, ect.
Old Sep 10, 2010 | 10:35 AM
lsneo's Avatar
dude too many variables to consider.
Old Sep 10, 2010 | 10:37 AM
Schister66's Avatar
Man U FTW
We can sit here and guess all day, but with so many variables to consider, it's pretty much all speculation. Why don't you talk to your tuner, address your goals for the setup, and let him decide what is safe for your setup.
Old Sep 10, 2010 | 01:35 PM
Silva Bullit DC4's Avatar
OP, you're going about it backwards. Do NOT let max psi dictate your setup. (I know I've said this 1000 times but), different turbos make different power at the same pressure level.
The key to a good turbo setup is to choose a power goal FIRST. Then plan your setup accordingly. Make sure your goal is within reason & limits of your setup & purpose of the car,choose the right size turbo , injectors, etc. to match your goal, discuss the goal with your tuner, & he will use whatever psi your setup will give him to make that particular power goal.
Old Sep 11, 2010 | 02:08 PM
jedsus617's Avatar
when u build a turbo motor, u dont build for how much boost, u build for power u want.. the block is sleeve so that a plus.. i would just leave it at 15lbs..u got 10;5;1 so no need to worry about lag
Old Sep 11, 2010 | 02:28 PM
civic2slo's Avatar
I understand what everyone is saying. But i'm trying to figure out my max boost psi and decide what turbo to get. I don't want to get a turbo that is almost maxxed out at a certain psi and decide to go higher psi and have to upgrade. Let say the block can handle 25 psi then I would go find a turbo that would be good to 25 psi at 9000 rpms. So that I would be running the turbo at about 80-85% of maximum at 20 psi.
Old Sep 11, 2010 | 02:33 PM
civic2slo's Avatar
I guess power goals are around 400-450 hp for now. Don't know if I have to swap out the 10.5 to 1 pistons though.
Old Sep 11, 2010 | 02:38 PM
dickie691986's Avatar
Keep turning the boost up till you bend a rod or break something. Then turn it back about 5lbs or so to keep it from happening again.
Old Sep 11, 2010 | 02:41 PM
jedsus617's Avatar
no need to swap out the piston! u be fine... a t60-1 should do the trick
Old Sep 11, 2010 | 02:42 PM
jedsus617's Avatar
lmao
Old Sep 11, 2010 | 02:43 PM
civic2slo's Avatar
Why don't you go do that and tell me when your engine blows up so that I can say glad it ain't my engine.
Old Sep 11, 2010 | 02:47 PM
I did and it held 470 on stock sleeves till it let go. but in all honesty just let it up to your tuner to decide on when to call it quites. I told my tuner to keep going. I knew it was going to blow at some point and now I have my reason to build a bigger and better car.....
Old Sep 11, 2010 | 02:52 PM
civic2slo's Avatar
Not being a sacastic or anything... But some people don't have the time or money to keep replacing or rebuilding engines. I would like to do it right the first time. If something unfortunate happens then I go from there.
Old Sep 11, 2010 | 02:53 PM
civic2slo's Avatar
Thanks I will look into that.
Old Sep 11, 2010 | 02:55 PM
I can understand that. I dont have the money to do that either. I was just to lazy to have my block sleeved and now its costing me an arm and a leg. lol but its whatever I have yet to regret anything....
