Boost creep issues
Old Sep 4, 2010 | 04:55 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Boost creep issues
I have an external waste gate on my D16Z6 with a holset HX25
The waste gate is not routed back into the exhaust.
I am running 7 psi, but if I stay in third gear all the way down to redline, boost slowly creeps to 9~10 psi.
I was wondering if an electronic boost control could fix that.
Something like this:
Old Sep 4, 2010 | 11:26 AM
Muckman's Avatar
Moderator in Chief
Default Re: Boost creep issues
Probably not. The wastegate is overwhelmed. Either its not big enough or not in an ideal location to bypass enough exhaust.
But on another thought. Boost creep isnt always bad as long as its not extreme. I bet your torque curve is kept nice and flat all the way to redline bc of the added boost.
Old Sep 4, 2010 | 12:34 PM
2k.civic.si's Avatar
speaking of this...who makes a good boost vs rpm controller?
Old Sep 4, 2010 | 02:52 PM
jetspeedz's Avatar
you need a bigger WG probably, a boost controller allows you to add boost not take boost away. The spring determines the lowest boost pressure you run. good luck
builtboostedteg
Apr 5, 2006 05:19 PM
dallasyoung
Feb 3, 2003 04:56 PM
Snafu-Si
Mar 5, 2002 02:07 AM
riot
Feb 1, 2002 09:33 AM
SIK IN DA HED
Sep 13, 2001 03:16 AM
