I need help/info about clutches for turbo B16A.
SO ive got a stock clutch on my turbo B16A along with a B18C tranny. Went for a drive the other day..more of a rip and the clutch was cooking smelt like a crackhouse in my car. I was recommended a stage 3 clutch so i need to know what brands specific i should go ahead with.
Can i just buy an after market stage 2,3 clutch disc, use my stock pressure plate, and get a lighter flywheel? OR would i be better off buying a whole stage 2,3 kit? I have no idea. Ive changed clutches before but that was on my em2 stock replacement for clutch disc alone. so help me out a little thanks!
ALSO Someone gimme tips/suggestions on how I would know my clutch is wearing/dying slowly? Besides slipping out of gears very low clutch pedal feel etc. Anything more specific? I know I've got a few months left depending how I drive it but I gotta have it done anyways thanks.
Re: I need help/info about clutches for turbo B16A.
ok man i am going to say get a comp stage 4, 6puck with springs. i have a turbo b16 at 7psi it works awesome. I have the stock fly wheel also. The stock clutch wont last much longer unless you stay out of boost. If you need to find a place to buy the comp clutch kit PM me i will send you to the person i bought mine from was cheapst i could find around 325 for the whole kitt. G.l
There are several handling capacity in each stage.. it all depends on the brands/models.. so you cant choose a clutch by their stage? you can only choose a clutch by their capacity to handle more or less torque.. it all depend on how much power you push..
1 Post
You'd know if your clutch is dieing, or slipping if you put load on it and the rpm's go up but your mph stay the same ( kind of like a burn out ) .
