C/R for boosted jdm gsr
Hey honda tech. I'm curious to know if a 10.1 compression ratio would be a hair too much for a build consisting of the following:
Jdm GSR b18c Head:
Skunk2 pro series valvetrain
Skunk2 pro1 camshafts
Skunk2 pro series intake manifold
No headwork.
Jdm GSR b18c Block:
10:1 comp pistons
Forged rods
Stock sleeves
Turbo/Exhaust:
Gt35r .82 a/r
Ramhorn Manifold
Full 3in exhaust, no cat
Fuel:
255 fuel pump
RRFP regulator
1000cc ID injectors
This setup is for a DD on 93 octane. Looking for 500whp on that octane peak numbers, but around 300 to 400whp for daily. Plan on tuning it with Neptune.
My tuner is pretty good, just wanting some opinions/insight on someone who maybe has ran a similar setup for DD.
Jdm GSR b18c Head:
No headwork.
Jdm GSR b18c Block:
10:1 comp pistons
Forged rods
Stock sleeves
Turbo/Exhaust:
Gt35r .82 a/r
Ramhorn Manifold
Fuel:
255 fuel pump
RRFP regulator
1000cc ID injectors
Re: C/R for boosted jdm gsr
Sorry I didn't specify. I'm not looking to DD 500whp, just peak #s.
I'll be setting bp at whatever gets me 300-400whp daily. I have yet to decide..
Did you tune your setup on any other fuel with a lower octane level? (I believe e85 is equivalent to 107 octane.)
If so what numbers did you make safely?
Up for more info!!
Up for more info!!
exactly man im at 10:1 i have been for 2 years now, and it hasnt blown a motor yet.
I have had some rod bolts let go though just falling out killing the motor, but thats it
10:1 will be fine like everyone stated. If I'm not mistaken Speedfactory is running 8's with a 10.8:1 compression motor. Best investment ever NLR AMS 1000.
I had a stock jdm b16 sir2 10.4:1 boosted to 7psi as a DD awhile back and no issues at all. The turbo needed a rebuild before the engine ever did. Don't always believe the hype and myths that you have to run "lower c/r" in order to boost.
