Anyone ever run into this with file fit rings....
JE pro seal rings. Had the block set to .0035 PTW clearance which I later saw was an error on my part. I read the data for the 2618 pistons vs the 4032 ones. Different metals, different expansion rates, different PTW clearances. Anyways, didn't think much of it. When I went to fit the rings, I didn't have to file one single ring. They were all within the factory Honda max end gap specs. Again, didn't think much of it.
The engine runs well, from what I can tell. Makes great power (I have yet to verify at the track or dyno) and seems to be getting great mileage for a boosted setup (averages 28-30mpg). The problem I have is it, randomly, likes to consume oil. I had a friend follow behind me once and he said it smoked like hell under load. I never saw it in the rear view but the other day after engine braking to slow down, I got back on it when the light went green and saw a decent sized cloud appear. Oil consumption sometimes is very minimal, other times its pretty heavy. Im beginning to wonder if this has something to do with the rings and the PTW clearance. Compression shows 185-195psi cold, and raises 10psi each cylinder for operating temp test. Leakdown was ~ 7% for each cylinder. Stem seals are brand new, all gaskets/rings/pistons/rods/bearings/pump, etc are newer also.
Re: Anyone ever run into this with file fit rings....
Stock PCV system with the breather port on the top of the valve cover vented to atmosphere. Boost is at 9psi right now. I did disconnect the PCV line at the intake manifold and plugged the port on the manifold. I noticed a very very small amount of "smoke" coming out the PCV hose line. Im not an expert, but I would assume a small amount of blow by is normal. If I bring the RPMS up, the pressure from this line decreases.
Don't forget to inspect the turbo. Look for oil soot behind the turbine heatshield or oil in the compressor housing. Too much crankcase pressure can cause this. Also worn turbo bearings from too little oil flow (if you have been using a restrictor) can cause seal leakage. A good low restriction breather is a necessity. A crankcase vacuum pump works even better.
Regarding the ring end gaps, the max Honda new spec is only 0.014 inch for the top ring. That is too small for a turbo application. The rings should have come with end gap recommendations for several different applications. Use their recommendations. Since you have assembled the engine already, put some low boost miles on it before you turn up the boost in 3rd, 4th or 5th gear. This will open the end gaps somewhat.
The blow-by will increase under load. Crankcase pressure can decrease ring seal. Are these "low tension" rings?
I am running 0.0045 inch PTW clearance with CP pistons in a sleeved B20. No restrictor and #4 line on a T4 turbo. I have zero smoke BUT I am using a crankcase vacuum pump set to 8 inHg. I am sure this is overkill.
I believe many folks here will recommend that you improve your breather setup. This is certainly the easiest and cheapest thing to do at this point.
Assuming we are talking about an 81 to 84 mm bore, the top end gaps sound fine. The second ring gaps are safe but some will argue that they should be larger than the top to avoid top ring flutter and loss of seal. If the second ring is an iron napier, it will wear in pretty quickly and the end gap will open up rapidly. The bottom line is that your end gaps are fine.
i think your gaps are off, or at least the top ring is. im also using je proseal rings. my top gap is .022 and 2nd ring is .025. all this on an 84mm bore.
ideally you should be about .018 top and .020-.021 2nd ring.
also, when you put the oil consumption rings in, did you make sure to sit the 2 skinny rings into the ringland after the grooved ring? are those gaps staggered out about 15 degrees each?
EusebioSam19
10-28-2012 06:39 AM
Drag-On
04-06-2004 11:52 AM
