buddy club spec III cams on turbo?
Old 09-03-2010, 08:05 PM
teg_racer's Avatar
Default buddy club spec III cams on turbo?
ive done some research on this and came up with one thread with no results.
im wondering if i installed my bcIII cams on a fully pnp head and about 10-15psi will then perform or hinder.. i also have some b16 cams but i dont have the resources to tune both and compare. has anyone tried boosing on these cams and what were your gains or losses.
thanks guys
Old 09-03-2010, 09:28 PM
Attaus's Avatar
Default Re: buddy club spec III cams on turbo?
Naturally aspirated cams are not designed for boost. They will work, but you won't make as much power as a cam ground for boost.
I can't seem to find the specs but I think you would be better off using the stock cams. If I knew the overlap specs for both I might be better able to tell you.
Old 09-04-2010, 06:40 AM
teg_racer's Avatar
there a little less lift than itr and more duration, i figure there a very mild street cam for between 10:1 and up compression. so if i boost at 10:1 shouldnt i have the best of both?
Old 09-04-2010, 03:56 PM
ABK
ABK's Avatar
duration is what you don't want on turbo cams, it will lead to too much overlap and air will just fly out of exhaust. You want more lift about the same as stock duration and overlap.
Old 09-04-2010, 05:41 PM
teg_racer's Avatar
so you think id be better off with my b16 cams? i already have both. the bcIIIs are in my na car till i install my pro2's. so i figure id try them or just keep it original
a1320honda
03-20-2012 07:24 PM
Spawne32
10-22-2010 03:11 PM
Pr0j3ctxH@tchx90
04-20-2007 03:38 AM
Charlie Moua
03-31-2003 08:30 AM
4ghatch
02-02-2003 09:36 PM
Quick Reply: buddy club spec III cams on turbo?
