Seeking to hit 500 whp. Input please!
Old Aug 28, 2010 | 07:32 PM
boosted.si04's Avatar
Default Seeking to hit 500 whp. Input please!
golden eagle Sleeved b18c1
84mm bore
9:1 arias pistons
eagle rods
acl bearings
integra type r head With ctr cams
b16 tranny with a stage 5 cc.
Only two things that worry me are the
Single walbro with aem fuel rail with fpr.5zigen wheel
750cc rc injectors.
Just those 2 things worry me.
Turbo is 62/62 precision turbo. .70 A/R .63
so I'm hoping to hit 500 on pump! So please let me know what you know or have experienced. Thanks
Old Aug 28, 2010 | 07:48 PM
TheShodan's Avatar
Moderator
Default Re: Seeking to hit 500 whp. Input please!
google search Honda-tech and Precision 6262. plenty of threads regarding this. check them out.
Old Aug 28, 2010 | 08:44 PM
QUICK8CIVIC's Avatar
This ain't impossible till you do it..alot of guys are posting Hypoyhetical setups w/o the true motor in the stands yet.
Old Aug 28, 2010 | 10:38 PM
SI_frankenstein's Avatar
I hit 520 with 1000cc injectors and a t3t67 on 18psi, I believe it was between 60-70% duty cycle on a 93 and 110 blend.
Old Aug 28, 2010 | 11:25 PM
Audia42's Avatar
I have almost the same set up but dual walbros and 1200cc injectors on e85 made 530 at around 80% duty cycle so I think you will be pretty close on 93
Old Aug 29, 2010 | 01:08 AM
a single Walbro can do it paired with 1000cc or larger injectors.
Old Aug 29, 2010 | 06:00 AM
jdmturboitr's Avatar
With what kinda tuning? Hondata? Ectune? Neptune? Im on the same quest. I have a fully built ls/vtec....1000cc precisions, garret 60-1 .70 ar....
Old Aug 29, 2010 | 08:33 AM
Thanks For all the input. Ya it's going to be on the s300. Ya probaly will go with 1000cc injectors.
Old Aug 29, 2010 | 08:36 AM
How many psi?
Old Aug 29, 2010 | 09:52 AM
gizzmo222's Avatar
A friend with a similar set-up made 492 @ 20psi on 93 octane with a 6262.
Old Aug 29, 2010 | 10:37 AM
What fuel setup was he running?
Old Aug 29, 2010 | 10:40 AM
gizzmo222's Avatar
Single Walbro 255 intank fuel pump, Injector Dynamic 1000cc injectors, stock fuel lines.
Old Aug 29, 2010 | 10:45 AM
So how long has he had the single walbro running on his car with that power?
Old Aug 29, 2010 | 05:58 PM
Audia42's Avatar
How many psi?
26psi conservative tune
Old Aug 29, 2010 | 07:34 PM
racemycivic's Avatar
Been running the car with the 255 for over a Year. I made 492 on 19psi 520 on 20.5 psi but turned the boost back down to 19 incase i got a bad tank of gas. It was on 93 pump. I wouldnt worry about the walbro at all just get the 1000's and you should be good to go
Old Aug 30, 2010 | 12:41 AM
yzracer323's Avatar
Your missing some info on your setup, like turbo mani, wg, ect. But as far as fuel, I would recommend Injector Dynamics 1000cc injectors, heavier guage power wire for pump, mabey even a 044 inline pump. Other things that will make a big difference on turbo cars in that range are the intake mani(victor-x are good) and cams( like skunk2 tuner 1s). just a few tips, but hope it helps
Old Aug 30, 2010 | 07:40 AM
turbo is the precision 6262
itr head with itr manifold
ctr cams
Old Aug 30, 2010 | 07:43 AM
ok cool so on that power for a year you havent had any problems with the walbro. Thanks for all the input.
Old Aug 30, 2010 | 08:04 AM
Anyone using anything other than hondata making 450whp plus?
Old Aug 30, 2010 | 10:19 AM
ya it's possible. Buddy made 493 on pump on Crome. S300 just makes it easier on the tuner lol.
boosted97gsr
Aug 19, 2011 12:31 PM
turboman2.2
Feb 9, 2010 08:30 AM
Barbantus
Oct 31, 2007 09:28 AM
BG-Teg
Apr 9, 2007 07:58 PM
captainjdog
Sep 2, 2004 04:39 PM
