what does a missfire feel like?
Old Jan 1, 2004 | 02:38 PM
B_1_8_hatch's Avatar
Default what does a missfire feel like?
i think i have a missfire going on, not to sure though. what would a missfire feel like, or how could you tell you have a missfire?
i have msd sci with the plugs gapped at .030..plugs a ngk 2 degrees colder plugs than stock.
Old Jan 1, 2004 | 02:40 PM
boredracer408's Avatar
Default Re: what does a missfire feel like? (93hb)
bogging..lots of vibrations from the motor..look closely at your rpm gauge. And if its somewhat erratic then you can tell your mis-firing.
Old Jan 1, 2004 | 02:48 PM
tegasaurus's Avatar
Default Re: what does a missfire feel like? (boredracer408)
kinda like you're in a close competition in the 400m dash, then suddenly someone pushes you from the back, then from each side..
you'll definatly know when you're mis-firing. if you've ever accelerated over a bumpy terrain (shitty road) and your car kinda goes brrrrrr-BRRRr-brrrrrBRRRR.
i dunno how to explain it, but you'll know.
okay...then i guess its not a missfire cause its not vibrating and my rpms aren't erratic. it seems to happen when i let off the gas some. it sounds kinda like a little pop noise coming from the muffler. i don't have a cat, so could that have something to do with it? it usually does it when i let off the gas slow.
any ideas?
Old Jan 1, 2004 | 03:50 PM
viprcr1's Avatar
haha thats just extra fuel igniting in your exhaust pipe. Nothing to worry about.
Old Jan 1, 2004 | 04:46 PM
Default Re: what does a missfire feel like? (viprcr1)
damn...i moved my timing back cause i thought it may have been a little detonation or something. i guess i have to move my timing back to where it was.
thanks
Old Jan 1, 2004 | 04:51 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">okay...then i guess its not a missfire cause its not vibrating and my rpms aren't erratic. it seems to happen when i let off the gas some. it sounds kinda like a little pop noise coming from the muffler. i don't have a cat, so could that have something to do with it? it usually does it when i let off the gas slow.
any ideas?</TD></TR></TABLE>
backfire?
Old Jan 1, 2004 | 05:29 PM
viprcr1's Avatar
Default Re: what does a missfire feel like? (-iLLuZioN-B18C1)
back fire sounds nothing like popping....more like a gunshot..atleast on a smallblock v8 it does.
Old Jan 1, 2004 | 05:50 PM
popping, gunshot, same thing
afnan
Jan 17, 2014 06:08 AM
iixerOii
Jun 28, 2004 09:15 PM
HX_Guy
Dec 5, 2001 05:06 PM
B17aTrbo
Oct 29, 2001 04:14 PM
