boost
Old Dec 31, 2003 | 09:07 AM
91glassycrx's Avatar
Default boost
does any one know how much boost a stock 2003 celica gt bottom end will hold
Old Dec 31, 2003 | 09:47 AM
RedTegLS's Avatar
Default Re: boost (91glassycrx)
Hmmmm I dont mean to be a smart *** but did you check the name of this website? Ok Ok I meant to be a smart *** a little
Old Dec 31, 2003 | 09:52 AM
8200RPM's Avatar
local hippie
Default Re: boost (RedTegLS)
well whats the stock cr?
and how strong are the rods, internals, etc? do some research on celica forums for other peoples setup and experiences, etc
good luck
Old Dec 31, 2003 | 09:56 AM
M.A.R.C.'s Avatar
Default Re: boost (8200RPM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8200RPM &raquo;</TD></TR><TR><TD CLASS="quote">well whats the stock cr?
good luck </TD></TR></TABLE>
also be sure u can find a good tuning solution!
Old Dec 31, 2003 | 10:00 AM
ELSpool's Avatar
Check SCC mag, they had an issue awhile back about boosting a Matrix which is the same engine I think thats in the GT. Comp was high stock and they ran around 8 psi. It's a great write up, talks about making return fuel system, and other issues that happened during the project. The matrix ended up running low 14's.
Old Dec 31, 2003 | 10:17 AM
System-7's Avatar
well a celica gTS has a 11-1 compression so i'm assuming unless your're not using race fuel you can't boost much without detonation.
Old Dec 31, 2003 | 10:25 AM
Default Re: (System-7)
and to be a smartass i know that the naem of this site is i have a 91 crx getting ready for 20-25 psi the celica is a guys car thats in my car club
civic_66
Oct 24, 2008 03:24 PM
got_no_sol
Apr 14, 2008 05:18 PM
1FSTNDN
12
Dec 19, 2006 07:56 PM
darkcrx
Apr 3, 2004 08:39 AM
prdtr15
Sep 13, 2003 04:12 PM
