16g/SOHC
Old Dec 31, 2003 | 03:08 PM
evosol's Avatar
Default 16g/SOHC
as an alternative to trying to rig up an adjustable actuator arm for my 16g (to lower boost) is it possible to just block the internal wastegate porte and use a external waste gate? i'm sure its possible but i couldn't find anything on the topic.
Old Dec 31, 2003 | 04:04 PM
evosol's Avatar
Default Re: 16g/SOHC (evosol)
bump...
Old Dec 31, 2003 | 04:08 PM
b16ahybrid's Avatar
you could, but you may want to weld the flapper shut so it doesn't open slighlty causing pressure loss and slower spool. Just to be safe...
Old Dec 31, 2003 | 05:02 PM
Bailhatch's Avatar
Default Re: 16g/SOHC (b16ahybrid)
They already make O2 sensor housings that split the turbine exhaust from the WG exhaust. You just bolt on the housing and bolt on the external WG
B16CRXT
Jan 6, 2006 11:58 AM
IZsd
May 4, 2004 11:11 AM
Simple
Apr 13, 2004 10:40 AM
stickshiftt
Apr 6, 2004 08:17 AM
H22Prelude
Nov 22, 2002 10:35 AM
