check out what i made
Old Jan 1, 2004 | 12:57 PM
dfoxengr's Avatar
Default check out what i made
new vacuum manifold for my friend. pretty cool design IMO, runs additional 6 ports. all 1/4NPT.
nipple in pics is just an example
Modified by hybridvteceg at 5:13 PM 1/1/2004
igotyofire's Avatar
Default Re: check out what i made (hybridvteceg)
red X's
Old Jan 1, 2004 | 01:08 PM
dfoxengr's Avatar
Default Re: check out what i made (igotyofire)
fixing them now, they were too big.
Old Jan 1, 2004 | 01:17 PM
EMI's Avatar
EMI
wow tell me how that works
Old Jan 1, 2004 | 01:18 PM
dfoxengr's Avatar
Default Re: (EMI)
its just a vacuum log/manifold, similar to GE but different design. so you dont have to tee off of your current lines like 5 times.
Old Jan 1, 2004 | 01:27 PM
igotyofire's Avatar
Default Re: (hybridvteceg)
thats cool, what is it made out of?
Old Jan 1, 2004 | 01:32 PM
dfoxengr's Avatar
Default Re: (igotyofire)
acrylic, withstands something like 10,000 PSI, so he should be fine, lol. crystal clear also
Old Jan 1, 2004 | 02:16 PM
Derek14's Avatar
thats pretty bling for a DIY... nice job, i am gunna fab one sometime too
Old Jan 1, 2004 | 02:19 PM
Bailhatch's Avatar
Default Re: (Derek14)
cool design and good craftsmanship but woulden't that be kind of a mess with the lines going all diffrent directions?
Old Jan 1, 2004 | 02:24 PM
Cyphear's Avatar
pretty sweet. If it was easy to make, any interested in selling me one?
Old Jan 1, 2004 | 02:33 PM
dfoxengr's Avatar
all thanks to my new drill press and workplace in the garage
and for going in diffeent directions, home depot or other stores sell 90deg. fitting and all sorts of things that clean it up. and put it coming straight off of the manifold and pointing at whatever accesory you're hooking up.
cyphear PM me please.
Old Jan 1, 2004 | 03:06 PM
projecthybrid04's Avatar
r u going to start selling them, im interested
Old Jan 1, 2004 | 03:14 PM
dfoxengr's Avatar
Default Re: (projecthybrid04)
yeah i am i think. theres a website in my sig, but its only geocities, so im making one right now actually that wont keep going down.
Old Jan 1, 2004 | 03:21 PM
turbonitrousgsr's Avatar
Thats a creative design and looks pretty clean. I'll buy one if you start selling.
Old Jan 1, 2004 | 03:51 PM
dfoxengr's Avatar
Default Re: check out what i made (alternativeGSR1)
anyone interested PM me. i have a lot of free time.
Old Jan 1, 2004 | 07:29 PM
tommyten's Avatar
thats a nice little workplace you got going on there
Old Jan 1, 2004 | 07:58 PM
92HB_HB's Avatar
sounds interesting....
Old Jan 1, 2004 | 08:01 PM
FOrSfEd's Avatar
nice job
Old Jan 1, 2004 | 08:17 PM
dfoxengr's Avatar
Default Re: (92HB_HB)
thanks all
Old Jan 2, 2004 | 05:50 AM
EGlovr's Avatar
looks good D. real clean
Old Jan 2, 2004 | 06:05 AM
mike1114's Avatar
Default Re: (EGlovr)
I made mine out of the little black box that goes to to the cruise control. Its a backup for extra vacuum for the cruise control. Since I don't have CC anymore, I drilled holes in each side and four going down it and tee'd it into the brake booster line. I used jb weld around the fittings to make sure they are sealed. Kinda ghetto but free from parts I had laying around. Holds 10psi + no problems!!
NOw working on a Catch Can made outta an old honda power steering reservoir. I just need a copy of the endyn catch can directions!!
Old Jan 2, 2004 | 07:27 AM
90stockintegra's Avatar
Default Re: (mike1114)
tapping int acrylic is usually a bad idea, the threads dont hold very well. And because it is pipe thead, that may not be the best material, overtighten a little, and CRACK. DO you supply plugs for the ports that are not used? Because the holes are so close together...does that make it difficult to install fittings in adjacent holes?
Try making it out of aluminum?
Hope i didnt **** you off, just trying to help, it is a good, inexpensive, and effective design.
Old Jan 2, 2004 | 07:36 AM
igo4bmx's Avatar
Default Re: (90stockintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90stockintegra &raquo;</TD></TR><TR><TD CLASS="quote">tapping int acrylic is usually a bad idea, the threads dont hold very well. And because it is pipe thead, that may not be the best material, overtighten a little, and CRACK. DO you supply plugs for the ports that are not used? Because the holes are so close together...does that make it difficult to install fittings in adjacent holes?
i agree, it could crack easily with overtightening...
aluminum ones would be nice... especially if they had brackets to mount them somewhere
Old Jan 2, 2004 | 08:51 AM
TheShocker's Avatar
Default Re: (igo4bmx)
Good design!
Old Jan 2, 2004 | 08:54 AM
Hoosier Daddy's Avatar
Default Re: (TheShocker)
Looks good Now put it to the test!
