can i use 460 rx7 injectors on honda?
hello guyz i just bought some 460 rx7 injectors can i use them on my sohc d16y8? are their any mods i have to do or are they like dsm 450's? oh and can anyone tell me the settings for 460 cc injectors on vafc?
*EDIT* i just recieved these injectors in the mail. are these rx7 460cc injectors? they say denso on one side. and another question sorry but.. one of the plastic nipple part of the injector broke and one is cracked. can i still used it? here are pics. thanks
Modified by egturbo at 9:58 PM 1/8/2004
Re: can i use 460 rx7 injectors on honda? (egturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">hello guyz i just bought some 460 rx7 injectors can i use them on my sohc d16y8? are their any mods i have to do or are they like dsm 450's? oh and can anyone tell me the settings for 460 cc injectors on vafc?</TD></TR></TABLE>
I just got a set also. Yes you can sue them, if they are Saturated then you dont need a resistor box. Peak and hold then you need a resistor box. Mine are 86-87 non-turbo 460cc red tops.
Oh, and youll need something to adjust your fuel with because of the size of the injectors of course.
Re: (T-RO)
yea i got vafc. how can i tell if their saturated or not? i already have a resistor box for them if i need it do u know what % to adjust them to?
Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=415342 </TD></TR></TABLE>
aww doesnt say anything bout the rx7 460 injectors.
Re: (egturbo)
umm yeah it does\ then there's a bunch about which clips are needed and stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">I am using the 91 N/A RX7 460cc injectors. The 550cc are the Turbo ones for the 2nd gen RX-7's They work fine as well and no need for resistor box. If your using any 89-92 RX-7 injectors you will have to get the clips for them. If your lucky enough to find 88 RX-7 injectors, they use the same square injector clip design as with hondas and will not only bolt into the intake manifold, but will clip in as well without the need for a resistor box. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">84-85 | 13B NT | low | square | center | 680cc | orange | 195500-0900
86-87 | 13B NT | low | square | center | 460cc | red | 195500-1350
86-87 | 13B T | low | square | center | 550cc | tan | 195500-1370
88 | 13B NT | high | square | offset | 460cc | purple | 195500-1350
88 | 13b T | high | square | offset | 550cc | purple | 195500-1370
89-91 | 13B NT | high | oval | center | 460cc | red | 195500-2010
89-91 | 13B T | high | oval | center | 550cc | purple | 195500-2020
Re: (RenoRacing)
aww i dont understand the words that are comin out of the second quote. lol.. its weird it says the quotes were from me.. i didnt write that.
Re: (egturbo)
I just used the quote thing to put them in boxes it automatically does your name since I'm replying to your last post.
Year / motor / impedence / plug style / ? / size / color/ part #
i'm having a brain fart but put a multimeter up to em and see what the ohm value is. i'm thinking peak n hold is like 7 or something and saturated is 14. And take the pintle caps off if they're broken. Ya don't want that getting sucked into your chamber, all they do is protect the needle from getting gummed up.
Re: can i use 460 rx7 injectors on honda? (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">i'm having a brain fart but put a multimeter up to em and see what the ohm value is. i'm thinking peak n hold is like 7 or something and saturated is 14. And take the pintle caps off if they're broken. Ya don't want that getting sucked into your chamber, all they do is protect the needle from getting gummed up.</TD></TR></TABLE>
Exactly....Peak & hold are less than 8ohms with a multimeter, and Saturated are >10ohms. Ideally with a honda ecu you'll need about 12-16 ohms at the ecu.
Re: can i use 460 rx7 injectors on honda? (Scott - 93HB Si)
If you get the turbo RX-7 injectors there saturated also but 550cc's.I am running them with Uberdata and they work great.
