Integra question
Old Jan 4, 2004 | 04:27 PM
LsTurboIntegra's Avatar
Default Integra question
Does anyone know how much boost the stock b18b motor will hold.
Old Jan 4, 2004 | 04:30 PM
Mase's Avatar
Default Re: Integra question (LsTurboIntegra)
its not so much "boost" you can measure, because the b18b could take 20 psi on a very tiny turbo, vs lower boost levels w/ a huge turbo.
Its more along the lines of POWER the b18b can hold. The b18b's heads suck....
but anyways, it will surely handle 300 whp daily, i know first hand
Old Jan 5, 2004 | 10:01 PM
NVturbo's Avatar
O.G. triple O.G.
With a stock B18B and T3/T4 turbine.....8 psi is max because anything beyond that...the pistons will go!!!!!!
Old Jan 7, 2004 | 09:32 AM
incogNitto's Avatar
Default Re: Integra question (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">With a stock B18B and T3/T4 turbine.....8 psi is max because anything beyond that...the pistons will go!!!!!! </TD></TR></TABLE>
Sounds like one of the guys who hang around the shop where I dynoed my car. Just a few minutes before I did a 12 PSI run on a stock motor - and continue to everytime I choose to run high boost (which is often). As Mase said, it is power that you should be concerned about.
Old Jan 7, 2004 | 10:59 AM
RedTegLS's Avatar
Default Re: Integra question (incogNitto)
Wow mase I thought you would tell him to search.....anyway isnt engine tuning one of the most important parts?
Old Jan 7, 2004 | 11:25 AM
quikB18B's Avatar
Where did you read that Superstreet
Anyhow, yeah i would say 300 is a nice stoping point on the stock motor, and like Mase said it's not psi, because that varies from turbo to turbo, but hp is a more precise way to measure a motors limits.
Old Jan 7, 2004 | 03:33 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Integra question (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
Anyhow, yeah i would say 300 is a nice stoping point on the stock motor, and like Mase said it's not psi, because that varies from turbo to turbo, but hp is a more precise way to measure a motors limits. </TD></TR></TABLE>
Nah ..i dont drool over Stupid Street like you.... I am speaking from experience because in my cousin's setup (stock at the time) the pistons cracked and he doesnt even drive it hard that much...boostin @ 9psi.
Old Jan 7, 2004 | 05:45 PM
quikB18B's Avatar
Nah ..i dont drool over Stupid Street like you.... I am speaking from experience because in my cousin's setup (stock at the time) the pistons cracked and he doesnt even drive it hard that much...boostin @ 9psi. </TD></TR></TABLE>
So just because your cousins motor blew that means that is the max
Maybe you should do a search, there are tons of people making 275-325 whp on stock Ls 12-14 psi. and pleased don't say that they are not reliable because there is a handful of memebers/friends locally to me that have done it and not one motor has blown. I myself am tuning this month to 12-13 psi, ill let you and know how it goes
Not trying to be a dick, but 8 psi is by far not the limit of the Ls motor, I have seen it done over and over again.
Is your cousin using Fmu? If not what fuel management? Maybe that was the reason his motor blew. On fmu I would say 8 psi would be the limit on the Ls motor because of small injectors, and high fuel pressure from this bandaid type management.
Modified by quikB18B at 9:52 PM 1/7/2004
Old Jan 7, 2004 | 06:46 PM
thermal's Avatar
I'd like to know what the blown motor was using for fuel management as well... 8 psi is not really that much....
Joe-G
Jun 7, 2010 11:32 PM
99JDMLSBOOST
May 4, 2009 05:40 PM
Jtuned DC2
11
Feb 7, 2008 07:48 PM
FATBOYeg6
Feb 15, 2005 06:50 AM
H22CIVIC
Oct 22, 2001 04:10 AM
