I wanna' get 200whp, what else do I need...
This is my setup:
ZC motor
SRP 9:5.1 pistons
Eagle Rods
14B turbo
HF mani
johnnyracecar.com intercooler
2.5" piping/no cat.
450cc DSM injectors
AFC hack
FPR set @ 40psi's.
Right now is only boosting the stock amount of psi's. Which is somewhere between 7-8(right?). I haven't been to the dyno, but what else do you guys think I need?
Any advice will be appreciated...
Thanks!!!
ZC motor
SRP 9:5.1 pistons
Eagle Rods
14B turbo
HF mani
2.5" piping/no cat.
450cc DSM injectors
AFC hack
FPR set @ 40psi's.
Thanks!!!
hondata for 200whp, thats a little overboard dont you think?
I would suggest TurboEdit the following. Make a program with turboedit to deal with your timing and richen up your basemap. Then to fine tune use the AFC. That way you can tune while you are in your car, no need for a wideband, chipburner and such. And its still very affordable.
Re: (bigwig)
seems like your ready to go. If you do need to run more than 11-12 psi to hit your goal, Just turn up the fuel pressure a few psi and lean out the afc a few %. Then you can run 13> psi on the hack with no cel.
