Flat spot in first
Old Jan 3, 2004 | 06:38 PM
abeaujuin's Avatar
Default Flat spot in first
maybe it isn't my clutch or transmission that's messed up. I just played around with the car in first gear, I opened full trottle in first and it felt more like the fuel wasn't being burned properly as If the engine wasn't getting enough fuel or air. The hessitation lasted until 3,500 RPM then the kick comes in. Then I shut the car off, then attempt to restart it, it begins to idle like it's about to shut off. could the TPS be bad?
Old Jan 3, 2004 | 06:45 PM
Johnyquest's Avatar
Default Re: Flat spot in first (abeaujuin)
If your turbo, and your running the afc hack, then that explains the hard starts when hot (hold the gas 1/2 throttle when your cranking it right until it starts).
If you drive a honda, that explains the no power below 3500rpms. Try revving the **** out of it and dumping the clutch. That'll skip over that "dead spot" we all pretend doesn't exist.
Old Jan 4, 2004 | 07:12 PM
abeaujuin's Avatar
Default Re: Flat spot in first (Johnyquest)
I drove a friends car, same year and everything he didn't have that issue. Could this TPS cause this problem?
Eg5ir1
Oct 14, 2013 03:37 PM
neoc03
Aug 30, 2012 09:18 AM
AlAddiN|502
Apr 4, 2010 12:16 PM
Teaser
Sep 19, 2007 02:17 PM
vtecsiqt
May 20, 2003 12:39 AM
