Compression Drop!!!
Old Jan 2, 2004 | 05:40 PM
r1racer's Avatar
Default Compression Drop!!!
Ok...I was at R&D Dyno today and one of my injectors failed...so I replaced all four of them...ran good for a few runs then my number for cyclinder drops compression to 70...it was at 210 before the dyno and after the injector failed. Looked at the spark plug and its grey no carbon deposits though. What do you guys think it is? By the way I made 284 whp and 291 torque before the 4 gave out. Darin at R&D said it maybe the headgasket and or the head itself. Thank for all your help.
Old Jan 2, 2004 | 07:29 PM
boostn420's Avatar
Default Re: Compression Drop!!! (r1racer)
Probably ring lands. thats the most common part to break. that means new pistons.
Old Jan 2, 2004 | 07:40 PM
FredoSP's Avatar
how do you know the injector failed? (just Wondering)
Id say add a drop of oil and redo the compression test, then have a leakdown test done too. After those results I think we could offer a better solution.
I had cyc #3 ringland crack on me, my #'s were 180 90 190 210 (B16A2 10.2:1 CR)
Old Jan 3, 2004 | 12:33 AM
r1racer's Avatar
anyone else?
Old Jan 3, 2004 | 02:22 AM
r1racer's Avatar
Default Re: Compression Drop!!! (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">how do you know the injector failed? (just Wondering)
I had cyc #3 ringland crack on me, my #'s were 180 90 190 210 (B16A2 10.2:1 CR)</TD></TR></TABLE>
The injectors failed because it started to putt like a mother.
Old Jan 11, 2004 | 10:51 AM
Rob Dizzle's Avatar
what ever happended?
i read how your old engine had sleeves that dropped
u sure the shop did the install right this time around?
zhan28
Feb 23, 2008 07:19 AM
Mr.OB*GYN_Rhett
Aug 17, 2006 10:54 PM
snowblind7x
Apr 13, 2005 08:12 PM
DOHCarp
Sep 11, 2003 07:10 PM
civichbb18c
Aug 28, 2003 12:44 PM
