Largest turbo with Log manifold
Old Jan 3, 2004 | 08:52 PM
Silverbeast's Avatar
Default Largest turbo with Log manifold
Im running the maxrev manifold and currently have the t3/t4oe .60/.63AR stage 5 wheel 360 thrust bearing...etc. I have the 4 bolt exhaust flange and A/C, I have done a lot of searching and cant find anyone that has a larger turbo with the same manfold, etc.
Let me know... i wanted to switch to a Precision Sc61, but it looks like it's gonna be a while if i have to get a new manifold, turbo, and all new piping.
Thanks!
Old Jan 3, 2004 | 09:21 PM
Tinker219's Avatar
Default Re: Largest turbo with Log manifold (HoustonSi)
the precision SC61 w/an E housing should have the exact same EXTERIOR dimensions as your current turbo.
Old Jan 3, 2004 | 10:04 PM
Dr Drew's Avatar
Default Re: Largest turbo with Log manifold (Tinker219)
What are the flow comparisons between the T3/t04e and the sc61e ??
Old Jan 3, 2004 | 10:31 PM
Have you seen many people using the e housing? Any drawbacks?
I was just wondering about fitment because mine currently looks like this:
Old Jan 4, 2004 | 03:21 AM
rocket256's Avatar
nice setup! whats your numbers ?
Old Jan 4, 2004 | 04:01 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoustonSi &raquo;</TD></TR><TR><TD CLASS="quote">Have you seen many people using the e housing? Any drawbacks?
daaaamnnn clean
Setup? times?
Old Jan 4, 2004 | 08:04 AM
Default Re: Largest turbo with Log manifold (USDMDC2)
Setup is horribily long... but basically it's LS/VTEC fully built head and bottom end and turbo specs are up at the top of the post. Currently only running 5psi to get things tuned then the boost will be getting turned up a lot, when and if i ever get my Profecb from Hondadrven
Anyone else know about the SC61 with an e housing?
Thanks for the kind words about the setup.
Old Jan 5, 2004 | 08:54 AM
ANyone else use the 4 bolt precision that would bolt up here?
Old Jan 5, 2004 | 10:33 AM
mike1114's Avatar
Default Re: (HoustonSi)
I'm running a maxrev log mani with the same garrett style/size turbo you are.
If you grind some of the webbing away on the block, you could get a larger housing on there, maybe some where is the .70ish range????
Old Jan 5, 2004 | 10:35 AM
PM-Performance's Avatar
Default Re: (mike1114)
i had a t3/04e 60 trim and 82 ex housing , no fitment probs with mine .
Old Jan 5, 2004 | 12:24 PM
Default Re: (itr206)
was yours precision or garret?
I am specifically looking to get a SC61 with a 4 bolt exhuast flange, if they are available.
Old Jan 5, 2004 | 06:19 PM
mine is a Garret, would an SC61 be any bigger? i dont think it is.
Old Jan 5, 2004 | 07:08 PM
I dont think it's any larger with the e-exhaust housing.
*Boostwerks*'s Avatar
If you go with the optional 4 bolt housing, you will have the exact same orientation of the turbo as you do now.
No change in oil lines, or charge piping, or DP would be needed.
Old Jan 5, 2004 | 07:26 PM
Default Re: (Bryson)
thats exactly what i needed to know
Now who has one?
Old Jan 5, 2004 | 07:44 PM
PM this man...
Arturbo
He is precisions bitch. =P
Old Jan 5, 2004 | 08:15 PM
Muckman's Avatar
Moderator in Chief
Ive seen that same picture too many times all over this forum.
Old Jan 5, 2004 | 08:32 PM
Default Re: (Muckman)
You have seen me post that pic once on this forum. Please feel free to search and show me where i have posted it.
If you have a problem find the PM button.
Old Jan 5, 2004 | 08:35 PM
More that i think about it, its the 1st time i have ever posted pics of my engine, hell that were just taken about 3 weeks ago.
Old Jan 5, 2004 | 08:40 PM
STHPERFORMANCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Ive seen that same picture too many times all over this forum.</TD></TR></TABLE>
So have a warm cup of STFU...
Its a clean car...
SiRkid's Avatar
with an inline pro mani and the comp on the drivers side id say you would have enough room to put likt a t-88 or even bigger there *googly eyes*
Old Jan 5, 2004 | 08:41 PM
Default Re: Largest turbo with Log manifold (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">with an inline pro mani and the comp on the drivers side id say you would have enough room to put likt a t-88 or even bigger there *googly eyes*
I wanted to go to that same setup, but i didnt want to have to redo the DP and chargepiping. Plus it's TX, i need the A/C
Old Jan 5, 2004 | 08:44 PM
OnePointFive's Avatar
overrated.
i'm using the e housing, same turbo as yours actually.
the SC61 should fit no problem.
Old Jan 5, 2004 | 08:45 PM
You dont need no stinking A/C......
Just put the windows down and floor it
On Another note, The lovefab sidewinder manifold would adapt any turbo for the most part and u can keep your A/c and run a 3" DP
Just a slight set back of about $800 dollars
Old Jan 5, 2004 | 08:46 PM
Thanks, I'm definatley going to step it up to the SC61 with the e housing and the optional 4 bolt.
jdm_vtec
Jan 22, 2008 03:29 PM
SpiderSol
Nov 22, 2005 08:07 PM
dohcMONSTER
Jun 4, 2004 06:15 AM
b18cls1
Sep 18, 2003 03:19 PM
99teggsr
Jul 26, 2003 08:41 PM
