B16 Main bearing and rod bearings don't have a color anymore?
I bought a spare b16 block and decided to take it apart today so i can see what the insides look like.
Everything looks fine except the main bearings and connecting rod bearings don't have a color anymore. They usually have green, pink, or brown right? When I clean the bearings they have different numbers. Is the numbers supposed to take place of the color? Or does the color on the bearing fade away over time?
Modified by boredracer408 at 2:31 AM 1/4/2004
Re: B16 Main bearing and rod bearings don't have a color anymore? (boredracer408)
the color prolly fades away over time...I know sometime the brown becomes the yellow, so you might want to check the code on the crank/rod and the block anyway
stan
stan
Re: B16 Main bearing and rod bearings don't have a color anymore? (Flamenco-T)
courtesy of earl
https://honda-tech.com/zerothread?id=715505
92ehatch
11
02-17-2008 12:42 AM
