Whos using aem ems v.1.03
Just wondering who is running the 1.03 version, how do u like it compared to the older ones, pro's & con's? I know that the v.94 was very problematic and was wondering how this version was.
Re: Whos using aem ems v.1.03 (SpdFrk)
most if not all problems were worked out in the 1.03
they changed some things in it like setting up/controlling the idle added traction control etc etc.
its alot easier to use menu wise than the .94 and lower.
also if you don't know what something does a pop-up help menu is there to tell you what the function of the highlighted value does.
It also solved a problem where my engine would just cut out at like 4k rpm in 4th and 5th.
Re: Whos using aem ems v.1.03 (Foozball26)
the calibration setup is much more user friendly w/ v1.03, and i havent found any bugs, however, just like v.94, the only major time areas you will probably have to spend is on tip in throttle adjustment, its pretty much minimal but ive found on most b-series, there is still a slight hestiation on tip in throttle, and you will need to adjust your accel pump tables.
1.03 is awesome, the only known issue with this version is the traction control. that will be fixed shortly though.
i can fully tune anything in about 3 hours on a normal setup
[C]IRCA
10-02-2005 11:30 PM
