zex bottle heaters Good?
Old Jan 2, 2004 | 07:12 AM
tegon-gsr's Avatar
Default zex bottle heaters Good?
Is there an thing wrong with the zex bottle heaters cause they are like 110 bucks new but the nx heater is like 230?
Old Jan 2, 2004 | 08:09 AM
USDM 4G VTEC's Avatar
Default Re: zex bottle heaters Good? (tegon-gsr)
good to use on the spot
but i would not have one installed permanently...
after seeing pics fo a few cars that went KABOOM bc the bottle got too hot
Old Jan 2, 2004 | 08:10 AM
Killer_B's Avatar
zex bottle heater, sucks.
the thermostat does not heat the bottle, it only keeps it warm once you warm it up. its really not worth buying.
your best bet is to get the NOS bottle warmer. it brings an external thermostat that you *should* not instal. the only issue is that you have to remember to turn the bottle warmer off once the bottle is warm/hot. it will take about 5-10 minutes to get the bottle HOT.
you will have to time it. test it. check to see how long it takes to get the bottle at the temp that you desire. then you can just turn it on for 2 minutes at a time to keep it warm or hot as you desire.
imo, the Zex bottle warmer sucks.
Old Jan 2, 2004 | 08:12 AM
Killer_B's Avatar
Default Re: zex bottle heaters Good? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">good to use on the spot
after seeing pics fo a few cars that went KABOOM bc the bottle got too hot</TD></TR></TABLE>
the zex bottle warmer will *NEVER* heat the bottle enough to make the safety pressure blow-off valve open up. i used it during the winter and summer and it never even made the bottle warm enough to get 900 psi.
Old Jan 2, 2004 | 08:16 AM
laughinxxx's Avatar
New User
Default Re: zex bottle heaters Good? (Killer_B)
Dynotune has a pressure regulated bottle heater and it is reasonably priced. Most of teh people on PO.com are using it and none have had any complaints.
Old Jan 4, 2004 | 11:26 AM
Killer_B's Avatar
Default Re: zex bottle heaters Good? (laughinxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx &raquo;</TD></TR><TR><TD CLASS="quote">Dynotune has a pressure regulated bottle heater and it is reasonably priced. Most of teh people on PO.com are using it and none have had any complaints. </TD></TR></TABLE>
^^that bottle warmer sounds like a good investment if it is adjustable. pressure wise.
Hellraising-vtec
Apr 3, 2006 01:42 PM
accord2nv
Oct 9, 2004 02:53 AM
asubennett
Jun 3, 2004 12:58 PM
HatchedGTI
Apr 27, 2004 09:49 PM
tek_civic
10
Dec 18, 2002 01:34 AM
