how would a MSD ignition improve my idle on a turbo honda (ZC)
Re: how would a MSD ignition improve my idle on a turbo honda (djnikko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko »</TD></TR><TR><TD CLASS="quote">will the acceleration be more responsive/smoother??</TD></TR></TABLE>
Yes,I think so..The multi-sparking will clean up the idle too because instead of firing one spark every rev like stock it throws 3 or more over a 20 degrees crank duration every rev while under 3000-3300rpm.
Re: how would a MSD ignition improve my idle on a turbo honda (D-Man)
will a MSD ignition help me remove flat spots in the rev range? around 3800-4300rpm
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko »</TD></TR><TR><TD CLASS="quote">will a MSD ignition help me remove flat spots in the rev range? around 3800-4300rpm</TD></TR></TABLE>
not unless its ignition related not fuel. What ecu are you running on the ZC? The fuel curves from the Si ECU will always have a flat spot. Try a ZC ecu or a Zdyne with ZC tune.
BTW-Idle should be smoother, quicker starts, better mileage.
Randy
Randy
Jockobo
06-30-2004 01:46 PM
djnikko
03-03-2004 11:49 PM
