Boost on stock internals
Old Jan 2, 2004 | 12:08 PM
AintegraA's Avatar
Default Boost on stock internals
I did a search and didnt come up with anything. I have a 98 GSR and i was wondering what's the highest PSI i could run with it still being safe (meaning without blowing up my motor) I was thinking about running 8 but a few friends told me i would be fin on 10. Any info would be great
Old Jan 2, 2004 | 12:26 PM
baphomet's Avatar
Default Re: Boost on stock internals (AintegraA)
You have a lot more searching to do, but I am in a good and generous mood today
PSI does not matter so much really, as a big turbo at 10 psi can make the same power as a small one at 20 psi. You want to ask how much power can your stock engine handle. The general rule of thumb is 300whp max, but if you are special you can do more.
Old Jan 2, 2004 | 12:27 PM
sneakypete's Avatar
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread?id=648627
https://honda-tech.com/zerothread?id=547295
https://honda-tech.com/zerothread?id=177403
https://honda-tech.com/zerothread?id=603128
https://honda-tech.com/zerothread?id=522197
https://honda-tech.com/zerothread?id=502155
https://honda-tech.com/zerothread?id=298213
Are you sure that you searched, lol. You shouldn't have any problems at all running 10 psi on your gsr. Just make sure you have some sort of fuel management like hondata, aem, motec, or even uberdata chrome, etc. They are many different systems out there that can do the job, it just all depends what your hp goal is and how much you want to spend. Hope this helps.
Old Jan 2, 2004 | 12:28 PM
B18bEK's Avatar
don't worry about how much psi you can run. on a stock motor you can usually safely make 270 + whp and if you don't care about your motor ... turn it up a little more and find out what the limits of your motor are and share with the rest of us
Old Jan 2, 2004 | 12:31 PM
RedTegLS's Avatar
Default Re: (B18bEK)
On a GSR motor I would be a little more careful just due to the fact they are much more expensive to replace. I have an LS and they are a dime a dozen so once "someone" comes out and tunes my sh*t I will be turning up the boost!
Old Jan 2, 2004 | 12:58 PM
TurboJesse
Guest
Posts: n/a
Default Re: (RedTegLS)
im gonna run 18-20psi on a stock b16..with an sc61 too, people have pushed way over 400whp with stock motors, just don't expect it too last 50k miles..
Old Jan 2, 2004 | 01:27 PM
dfoxengr's Avatar
Default Re: Boost on stock internals (slashDEVslashNULL)
u can can goto the track and hit 22PSI on stock internals just fine, but everyday run around 12
Old Jan 2, 2004 | 01:32 PM
BoostedITR41's Avatar
Default Re: Boost on stock internals (hybridvteceg)
inline pro headgasket and block gaurd with a cartech FMU, missing link, 450cc injectors, 255lph pump, and vafc.
on that set up I run 15psi daily on a 84k mile B18C5 ITR block on stock internals
Old Jan 2, 2004 | 01:38 PM
TurboJesse
Guest
Posts: n/a
Default Re: Boost on stock internals (BoostedITR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedITR41 &raquo;</TD></TR><TR><TD CLASS="quote">inline pro headgasket and block gaurd with a cartech FMU, missing link, 450cc injectors, 255lph pump, and vafc.
on that set up I run 15psi daily on a 84k mile B18C5 ITR block on stock internals</TD></TR></TABLE>
im running there headgasket too with hondata, i run 14.7psi daily on a stock b16a
Old Jan 2, 2004 | 02:55 PM
turbocivic96's Avatar
Bone stock internal D16Y8 with 12lbs. of boost daily driven for 3 years now and never had a problem (120,000k). The key to making the motor last long is proper fuel and ignition tuning. I would spend some money and have a professional tuning shop dyno tune it. Im making 235whp with a 13.7 1/4 @104mph.
Old Jan 2, 2004 | 08:55 PM
AintegraA's Avatar
Default Re: Boost on stock internals (turbocivic96)
good deal , thanx for all the info guys.
97turboteg
Apr 7, 2006 07:28 AM
1990hondaHF
Aug 21, 2005 01:39 PM
Rocks
Jun 18, 2004 02:15 PM
fastsohc
Jun 10, 2004 07:32 PM
toooslow
Jul 10, 2003 02:21 PM
