HELP TURBO'D BUT NO BOOST! HELP!
Old Jan 3, 2004 | 07:11 PM
miketurbohonda's Avatar
Default HELP TURBO'D BUT NO BOOST! HELP!
on my ZC DOHC 1600cc
hey my turbo was fin today all plumbing done but no boosting can hear turbo whistling winning up but not any faster at all really whats the problem????
Old Jan 3, 2004 | 07:12 PM
Lucky_Smurf's Avatar
Default Re: HELP TURBO'D BUT NO BOOST! HELP! (miketurbohonda)
Check all your piping for leaks. What about wastegate it's not opening early is it? Do you have a boost gauge? Blow off valve? It's not stuck open? Check those things.
boostn420's Avatar
Are you sure all of your boost tube are connected.
Old Jan 3, 2004 | 07:15 PM
JonGP4's Avatar
Default Re: HELP TURBO'D BUT NO BOOST! HELP! (boostn420)
did u add turbo fuild?
j/k i'm having the same problem.. i've narrowed it down to a leak in my intercooler.. and wornout rubber hoses.. they expand to much. check all your piping.. you really need a boost gauge if you don't have one
Default Re: HELP TURBO'D BUT NO BOOST! HELP! (Lucky_Smurf)
all pipes connected dont know about waste gate maybe the tube that goes from turbo to waste gate one that you put a boost tap on i had my boost gauge tee'd into that and it read nuthin.
pretty sure nuthin leaking tho
Old Jan 3, 2004 | 07:22 PM
x2gold's Avatar
Drive the car (don't rev it) j/k.
Go over lines to intercooler like mentioned above. Always double check.
Check lines to boost controller and from wastegate or BOV and make sure they are connected. Most of the time the air escapes from an overlooked path.
Old Jan 3, 2004 | 07:27 PM
JonGP4's Avatar
Default Re: HELP TURBO'D BUT NO BOOST! HELP! (x2gold)
yup, thought cuz everything was connected i wasn't leaking.. but i was.. i'm ordering all new pipes from JC wittney so i hope that helps.. also getting the intercooler fixed.
but even if it was leaking some where only a bit it should still boost up a.
Old Jan 3, 2004 | 10:29 PM
It should boost but you never know. The air is going to take the path of least resistance which is any leak at all. You probably have multiple leaks. Were not bagging on your setup or your ability or anything but it has to be leaks. Another thing to check would be the exhaust manifold and turbo gastkets. If you've got a big leak there you wont get spool either.
Old Jan 3, 2004 | 10:54 PM
crap **** im dumb my manifold only has like 3 nuts on it outta like 7 grrrrrr will that stop it from boosting
hey i dont have a exhaust on it either just the dump pipe only finger tight on there
Old Jan 3, 2004 | 11:04 PM
InTeGrA B18b1's Avatar
yes it will. put the bolts on.
Old Jan 4, 2004 | 12:03 PM
Default Re: HELP TURBO'D BUT NO BOOST! HELP! (InTeGrA B18b1)
No bolts huh, lol. You might want to check out your gasket now. That much leakage could damage the gasket. Also tighten up your exhaust you need the back pressure.
Old Jan 4, 2004 | 08:32 PM
vaporboy12's Avatar
check your vacum lines for your wastegate
1sic3dr
Aug 11, 2007 03:28 PM
RFd15bhatch
May 24, 2005 12:27 PM
mattcalica
Jan 17, 2004 02:49 PM
haq
Aug 6, 2003 11:56 PM
