Anybody here run a solid read mount on G3 Teg??
Old Dec 31, 2003 | 09:27 PM
VTC_CiViC's Avatar
Default Anybody here run a solid read mount on G3 Teg??
Just curious to know if anybody esle here runs a solid rear mount on their G3 Integra. I ask because I filled a stock rear mount with liquid urethane from McMaster Carr and installed it when I did the tranny swap, but I wasn't able to line up the 2 lower holes on the rear mount bracket linking the mount and the block/tranny. I was able to bolt the bracket to the actual mount and to the block, but the 2 lower bolts that connect the bracket to the tranny won't line up whatsoever, so I was wondering if anybody esle with a solid rear mount in here has experienced this and what you did to get it bolted up. I'm considering unbolting the bracket from the mount itself so I can line up the lower bolt holes, get those in and then fight to get the bracket to line up with the actual mount, any ideas?
mercutio_07
Mar 19, 2008 04:35 PM
91BlueEF9
Sep 8, 2007 07:00 AM
scanz89
Mar 15, 2007 08:04 PM
vtechrex
May 26, 2006 01:39 PM
Combustion Contraption
Sep 29, 2003 09:15 AM
