BOOST GAUGE READING?!?! 64.4?
Old Jan 3, 2004 | 03:23 AM
djnikko's Avatar
Default BOOST GAUGE READING?!?! 64.4?
hi guys
i took my turbo crx ZC on its first test drive yesterday but have noticed the electronic boost gauge reads 64.4 and a load of other crazy settings, could it be detecting vacuum? cuz im pretty damn sure im not running 64.4 PSI...
where does everyone else hook their boost gauges to? what other units of measurement are used for PSI?
thanks
Old Jan 6, 2004 | 03:02 PM
djnikko's Avatar
Default Re: BOOST GAUGE READING?!?! 64.4? (djnikko)
bump!
Old Jan 6, 2004 | 05:02 PM
Del_Slowest's Avatar
mm hg
i'd give you link to conversion website but it's on my laptop and i don't wanna turn it on. 65 mm hg isn't very high though, i'm guessing 5psi or so
Old Jan 7, 2004 | 12:53 AM
djnikko's Avatar
Default Re: BOOST GAUGE READING?!?! 64.4? (Del_Slowest)
thanks mate, yeah conversion website would be handy. thanks for the advice
Old Jan 7, 2004 | 12:57 AM
djnikko's Avatar
http://www.onehalf20.com/GCT.htm
this seems to help
Old Jan 7, 2004 | 07:15 AM
djnikko's Avatar
ok so i took a deeper look at this chart did the maths and came out with a figure of a little over 1 PSI, this surely cant be correct? Im pretty sure i adjusted it to about 5 PSI a little more a little less maybe...
Please help me obae wan kenobe...
Old Jan 7, 2004 | 08:33 AM
i'll have to look at my vafc today because it idles at like -400 something and the boost gauge says between 17-20 VAC . what kind of gauge do you have?
don't drive the car until tonight if you can.
Old Jan 7, 2004 | 09:25 AM
lazerus's Avatar
64.4 sounds like Kilopascals to me.. [KPA]
1 kiloPascals = 0.145037738 PSI
In other words, you were running ~9.3 LBS of boost
-400 on a VAFC would be Millimeters of mercury. -400 MM/hg would be Appx -7.7 PSI or -53 KPA.
-17 - -20 is inches of mercury or in/mg and would be appx -6.5 - -4.5 PSI.
Brad
Modified by lazerus at 12:39 PM 1/7/2004
Old Jan 7, 2004 | 09:45 AM
djnikko's Avatar
Default Re: BOOST GAUGE READING?!?! 64.4? (lazerus)
The gauge is Race X, i cant find any info on the web about them and the instructions are no help at all apart from wiring. I have a mechanical boost gauge hooked up also so i'll check that one next time. do you hook boost gauges directly to vacuum? any vacuum source? cuz thats what ive done, the feed from the top of the inlet manifold...
Old Jan 7, 2004 | 10:49 AM
is this it
http://www.speeding.co.uk/acat....html
Old Jan 8, 2004 | 12:11 AM
djnikko's Avatar
yeah thats the one! just rung up for some more in depth instructions....
where do you guys connect into the vacuum source? do you use any vacuum source?
Old Jan 8, 2004 | 12:26 AM
ScrapinSi's Avatar
you can tee into the brake booster, or the back of the intake manifold... its personal preference really... some tap into the line directly off of the turbo... I prefer right off the FPR vaccuum line that way you are seeing boost IN THE MOTOR, not out of the turbo...
Old Jan 8, 2004 | 03:46 AM
djnikko's Avatar
Default Re: BOOST GAUGE READING?!?! 64.4? (ScrapinSi)
where can i find the brake booster? is it located at a common point on honda's? the engine I have is a D series simular to a ZC.
thanks for your input guys...
Old Jan 8, 2004 | 08:29 AM
brake booster is the fat line that is on the very top on the right side of the picture. it has a lil metal like thing which is called the check valve. you tap into the line before the check valve (closer to the manifold)
Old Jan 10, 2004 | 02:58 AM
djnikko's Avatar
thanks guys, you helped alot. I'll take a copuple of pics and post them on this thread when ive done it. by the way how do you post pics?
thanks
Old Jan 10, 2004 | 11:31 PM
you have to host them on a website. yahoo geocities has free hosting as well at imagestation.com
JDM_Acccord
Aug 13, 2007 09:41 PM
Azndude1983
Feb 15, 2006 02:24 PM
Goldfingiz
Oct 5, 2003 11:05 PM
Nameless RB26
Aug 13, 2003 02:00 AM
boostdB16a
Jul 9, 2003 04:48 PM
