An Uber-E-Turbo? Maybe...
Old Jan 3, 2004 | 05:06 PM
Hites
Guest
Posts: n/a
Default An Uber-E-Turbo? Maybe...
http://www.electricsupercharger.com/
http://www.electricsupercharger.com/eramvideo.mpg
^only makes ~1psi, but it looks like fun to play with at least . i decided to check out if this was just another ebay pos knockoff, but i found it to actually be quite different. the ebay one i found claimed to push 240 cfm, but this eram thingy pushes 750 cfm. isnt something for a serious racer, but for a simple bolt it appears to makes half-*** gains . i just want one so i can let it fly like in the video .
Old Jan 3, 2004 | 05:28 PM
tegasaurus's Avatar
Default Re: An Uber-E-Turbo? Maybe... (Hites)
looks liek it would take more power to push the fan then the 1 psi of pressure would create.
Old Jan 3, 2004 | 07:02 PM
Hites
Guest
Posts: n/a
Default Re: An Uber-E-Turbo? Maybe... (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">looks liek it would take more power to push the fan then the 1 psi of pressure would create.</TD></TR></TABLE>
at least it runs off of the battery so theres no parasitic loss like a supercharger.
Old Jan 3, 2004 | 07:43 PM
boostn420's Avatar
yes, there is the alternator is what picks up the work. the current drain on the battery makes the alternator work harder.
Old Jan 3, 2004 | 09:31 PM
Hites
Guest
Posts: n/a
Default Re: An Uber-E-Turbo? Maybe... (boostn420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">yes, there is the alternator is what picks up the work. the current drain on the battery makes the alternator work harder.</TD></TR></TABLE>
from the website that i linked: "SAFE FOR YOUR ELECTRICAL SYSTEM: High current for short duration is drawn directly from your battery, not your alternator. Just like your starter motor."
*ahem*, you were saying?
Old Jan 3, 2004 | 09:39 PM
m R g S r's Avatar
It doesn't seem like it's worth it if it will only push 1psi. Isn't that less then 10hp on a 4 cyl honda?
Old Jan 3, 2004 | 10:28 PM
Hites
Guest
Posts: n/a
Default Re: An Uber-E-Turbo? Maybe... (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't seem like it's worth it if it will only push 1psi. Isn't that less then 10hp on a 4 cyl honda?</TD></TR></TABLE>
right now im looking for an sc400 at a decent price (if i can sell my damn car ), and any form of fi for an sc400 is $5k+; thats way out of my budget. i might just replace the air box with one of these with a k&n plopped on the end.
hrs-parker
Apr 29, 2008 06:15 AM
adam081904
Nov 8, 2007 04:36 AM
Z Darkside
Honda Motorcycles
34
Aug 14, 2006 06:16 PM
Screaming
14
May 30, 2006 12:07 PM
DAsix
Acura NSX
Sep 9, 2004 08:00 PM
