oil pressure light
Old Jan 4, 2004 | 05:11 PM
IH82LOSE's Avatar
Default oil pressure light
i got a friend who has a ls turbo. we ran once then we came up to a light...the oil light turned on. took off from the light, then oil light turned off. whenever he comes to a stop the oil light comes on. oil was added, but the light still stays on. any ideas of whats going on? then it started knocking after the oil pressure light came on.
Old Jan 4, 2004 | 06:16 PM
Honda Hick's Avatar
Default Re: oil pressure light (IH82LOSE)
Sounds like you're killing the motor. There might be something stuck in the oil pickup or a passage and your engine isn't getting the oil it needs. Or the oil pump is going. Either way, it looks like your friend is on the way of having a dead motor. The oil light means turn engine off immediately. Don't **** with it.
Old Jan 4, 2004 | 06:36 PM
JonGP4's Avatar
Default Re: oil pressure light (Honda Hick)
yup.. sound like you and your friend aren't to bright.. sorry but if my oil light came on first thing i'd do is turn the motor off and coast off the road.. something is diffently wrong
Old Jan 4, 2004 | 06:40 PM
boostedsolv10eater's Avatar
Default Re: oil pressure light (JonGP4)
haha why why why why would you ever take off from a light with that light on!!! you might have just poped his motor. nice going. anyways sound like your oil pump went. get another one and then check your compresion, and cross your fingers thats you didnt burn up a ring or two. good luck and next time when a oil light come on and the engine is making loud banging sounds, turn the motor off!
Old Jan 4, 2004 | 07:55 PM
Bailhatch's Avatar
Default Re: oil pressure light (boostedsolv10eater)
the knocking is most likely a spun or gouged bearing in the bottom end IMO
Old Jan 4, 2004 | 09:15 PM
Cyphear's Avatar
did you check the dipstick?
Old Jan 5, 2004 | 07:36 AM
hondaeg8's Avatar
Default Re: oil pressure light (Cyphear)
i would think spun bearing.
the guy is at a light...you guys want him to turn the motor off and then what? block traffic for awhile?
Old Jan 5, 2004 | 07:48 AM
Nextelbuddy's Avatar
Default Re: oil pressure light (stockhatch)
ive blocked traffice before becuase of something that was wrong with my motor. im sorry but my car comes first. that and all the money thats been dumped into my motor. im not going to risk messign up anything more moving out of the way under the motors power just people in traffic can move freely lol.
Old Jan 5, 2004 | 07:58 AM
omahaturbocivic's Avatar
Default Re: oil pressure light (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">the knocking is most likely a spun or gouged bearing in the bottom end IMO</TD></TR></TABLE>
Yup, the loss in oil pressure was probably due to one of the bearings being worn or spun causing the clearances to be too loose which was the early sign of bearing issues. Then it quickly beat the bearing up and started to knock.
Old Jan 5, 2004 | 06:54 PM
hondaeg8's Avatar
replace that bearing and you should be good to go.
would it be best for him to replace all the bearings?
any chance the crank may have gotten messed up?
tell him to build it for boost since its going to be apart anyway
Old Jan 7, 2004 | 06:00 AM
Cyphear's Avatar
Doesn't oil pressure increase as RPMs increase? Couldn't he just be low on oil? And yeah, the other day i stopped in the middle of the street when my oil light went on.
jdm-ek-si
Apr 18, 2008 02:02 PM
hillsidedrill
Jul 19, 2007 06:48 PM
runderwo
Mar 29, 2007 10:39 AM
notstock93
Dec 23, 2004 02:13 PM
IH82LOSE
Jan 4, 2004 05:16 PM
