Rebuilding engine for Turbo
Old Dec 31, 2003 | 03:12 PM
WhiteHype08's Avatar
Default Rebuilding engine for Turbo
I'm new to rebuilding engines. What are the key things i'm gunna need to replace for a high amount of boost, I would also like to know what I will have to replace to up my redline?
I'm gunna be working with a GSR engine.
Thanks
Old Jan 1, 2004 | 02:23 AM
RAWB's Avatar
Default Re: Rebuilding engine for Turbo (WhiteHype08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteHype08 &raquo;</TD></TR><TR><TD CLASS="quote"> What are the key things i'm gunna need to replace for a high amount of boost, I would also like to know what I will have to replace to up my redline?
Might want to start with your "S", "E", "A", "R", "C", and "H" keys, unless they're broke- your answers will be found
Old Jan 1, 2004 | 05:35 AM
Mikeyslude's Avatar
What do you mean by high boost? Sleeves, pistons, rods, bearings, valvetrain, fuel system, a few gauges, engine management & custom kit should make you safe for "high boost".
Old Jan 1, 2004 | 07:36 AM
Muckman's Avatar
Moderator in Chief
Replace your redline with an aftermarket one!
Old Jan 1, 2004 | 10:03 AM
-iLLuZioN-B18C1's Avatar
as far as the block goes, sleeves, rods and pistons.
as far as raising redline, you need to work on the head. valves,retainers, springs
Old Jan 1, 2004 | 10:05 AM
TurboJesse
Guest
Posts: n/a
Default Re: Rebuilding engine for Turbo (-iLLuZioN-B18C1)
how much power do you want? thats the most important question..
Old Jan 1, 2004 | 10:13 AM
Mase's Avatar
Default Re: Rebuilding engine for Turbo (Mpir3)
i think we need to make this forum so the trial users cant post yet until they use the search atleast 10-15 times
Old Jan 1, 2004 | 11:11 AM
Default Re: Rebuilding engine for Turbo (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">i think we need to make this forum so the trial users cant post yet until they use the search atleast 10-15 times </TD></TR></TABLE>
good idea, lol
Old Jan 1, 2004 | 03:06 PM
xtal's Avatar
You'd be better off spending sleeving money on a good bore/hone job and an aftermarket ECU. Unless you have a H22. My 0.0020..
Old Jan 1, 2004 | 03:10 PM
Default Re: Rebuilding engine for Turbo (xtal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtal &raquo;</TD></TR><TR><TD CLASS="quote">You'd be better off spending sleeving money on a good bore/hone job and an aftermarket ECU. Unless you have a H22. My 0.0020.. </TD></TR></TABLE>
are you saying boring/honing stock sleeves is better than buying aftermarket sleeves?
Old Jan 1, 2004 | 04:19 PM
viprcr1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
are you saying boring/honing stock sleeves is better than buying aftermarket sleeves?</TD></TR></TABLE>
No he is saying that not everybody should buy sleeves when they are boosting. Its just a new bandwagon. If you are only making 200whp there is no need for sleeves. What is really important is your engine/fuel management which will keep everything together if a tune is good.
Old Jan 1, 2004 | 04:26 PM
TurboJesse
Guest
Posts: n/a
Default Re: Rebuilding engine for Turbo (viprcr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viprcr1 &raquo;</TD></TR><TR><TD CLASS="quote">
No he is saying that not everybody should buy sleeves when they are boosting. Its just a new bandwagon. If you are only making 200whp there is no need for sleeves. What is really important is your engine/fuel management which will keep everything together if a tune is good.</TD></TR></TABLE>
agreed, there are people pushing over 400 on stock internals...Tuning/EMS is VERY important..
JZs15
Feb 26, 2009 03:21 PM
CB5F22A1
Oct 9, 2005 01:46 PM
FalconMan
Feb 3, 2003 02:01 PM
99SilverEx
Jul 6, 2002 11:28 AM
Gonzo
Feb 18, 2002 03:09 PM
