Best Built and cost?
Old Jan 3, 2004 | 10:03 AM
Dyno Queen's Avatar
Default Best Build for best cost?
Who could do the best build for the best cost, what im looking for is, a RS, GE, Benson.....sleeved gsr block, CP pistons(9.0:1) Pauter rods, all balanced and blueprinted i want it around a 83mm bore, i have a core block to send u guys let me know what you can do and what the turn around time would be, thanks alot
this is a turbo build up for around 25-30psi
mike
Old Jan 3, 2004 | 10:31 AM
igotyofire's Avatar
Default Re: Best Build for best cost? (turbo gsr)
Dart?
Old Jan 3, 2004 | 10:32 AM
Dyno Queen's Avatar
Default Re: Best Build for best cost? (igotyofire)
i dunno? i mean i want to send my block to have it fully built for the best price!
Old Jan 3, 2004 | 10:34 AM
94gsr4dr's Avatar
personally i would just contact earl, and he has everything you would need a great prices and customer service
Old Jan 3, 2004 | 10:35 AM
Dyno Queen's Avatar
Default Re: Best Build for best cost? (94gsr4dr)
that is definately an option, i have heard nothing but good things about him, thanks guys anything else?
Old Jan 3, 2004 | 10:40 AM
tegasaurus's Avatar
83mm bore is going to make the cost quite a bit higher. 81mm and 84mm are going to be your cheaper options because those are "off the shelf" pistons because integras and CRV blocks are 81/84 stock.
When you start getting crazy random bores the price for pistons increases $150 or so.
Old Jan 3, 2004 | 10:54 AM
Dyno Queen's Avatar
Default Re: Best Build for best cost? (tegasaurus)
ouch, i didnt know that, but wouldnt 84mm be cuttin it a lil close with the sleeves?
Old Jan 3, 2004 | 10:59 AM
94gsr4dr's Avatar
hell no people run 84mm with no problems at all.
Old Jan 3, 2004 | 11:01 AM
Dyno Queen's Avatar
wow that would be what a 1.9L almost a 2.0L?
Old Jan 3, 2004 | 11:23 AM
94gsr4dr's Avatar
i wanna say 1.94, but i can't remember, do a search its been covered
Old Jan 3, 2004 | 11:39 AM
earl's Avatar
CP does have an 83mm, 9-1 off the shelf size. I think it is a perfect starting place. It gives you room for several rebuilds in case you blow a tune-up and melt a piston. It takes me about 4 weeks from start to finish to do a short block
Old Jan 3, 2004 | 11:48 AM
Dyno Queen's Avatar
Default Re: Best Build for best cost? (earl)
oh ok i would rather go with a 83mm, what kinda cost would u do all that for new pumps gaskets etc.... im sure i would have to have a larger head gasket for the 2mm oversized piston, let me know so i can get mine ready for you this will be a hi boost application so i guess i would want it built basically like yours in the Crx, thanks and get back to me with a quote.
mike
Old Jan 3, 2004 | 01:50 PM
Dyno Queen's Avatar
prices guys
Old Jan 3, 2004 | 02:08 PM
94gsr4dr's Avatar
earl has a sale on pauters for 675 not sure if it is still goin, 475 for pistons with rings(atleast for 81mm, 83mm should be the same), and i believe the block is roughly 950 or so, just pm him and he will get back to you when he is online.
Old Jan 3, 2004 | 02:43 PM
Dyno Queen's Avatar
cool man thanks, for some reason my damn recent topics are messed up it wont let me search or got to my topics, says they are disabled by an moderator, or something hell if u big MODS see this free me up DAMNHITTTTT!!!!!!!
Old Jan 3, 2004 | 02:45 PM
94gsr4dr's Avatar
i have the same thing, but i think it is due to site maintnance not you personally
Old Jan 4, 2004 | 06:39 AM
Dyno Queen's Avatar
up
Old Jan 4, 2004 | 12:12 PM
Dyno Queen's Avatar
Default Re: (turbo gsr)
yup yup
Old Jan 4, 2004 | 01:08 PM
Dyno Queen's Avatar
give me some quotes!!!!!!! i need a motor
Old Jan 4, 2004 | 01:44 PM
tegasaurus's Avatar
Default Re: (Boosted Teg)
also, if you go with a crazy bore (ie 83mm) you're going to need a special headgasket, probably a cometic or a bored one from the machine hsop.
There will be no need to have your motor re-bored if its beeing built and sleeved now. get it 84mm and get it done right It'll be just that much cooler saying you have a 1.94 liter motor (2.0 if you wanna be a badass).
And if you want quotes, you're going to need to call companies and ask them. This isn't like those commercials that you see on TV where banks call you and ask you to take their lown with the lowest APR, you need to go out and find them urself (i'm not trying to be rude, im just trying to help u out to get what u need faster).
Are you willing to ship ur motor out and deal with out of state communication with the motor, or do you want to keep it local?
-Ryan
Old Jan 4, 2004 | 02:47 PM
Dyno Queen's Avatar
Default Re: (tegasaurus)
Ryan thanks bro for all teh help, yes im willing to ship it out to have it done, im not gonna get to crazy into the spending on it but i do want to make some power with it. I guess the engine builder will do the cometic gasket for me and i wanna go with CP so hopefully since its a "custom" piston they wont charge me an arm an a leg, but if u know anyone man let me know like i said pauter rods cp pistons are the ones that i want to go with so let me know if u can get a hookup or if you just got a reference for me, once again man thanks alot.
mike
Old Jan 4, 2004 | 03:08 PM
tegasaurus's Avatar
most people wont recommend this, simply because they've never tried it. I suggest buying the parts that you'll need (pistons, rods, bearings, rings) have your block sleeved, then have a local shop assemble it all together. That way if anything ever goes wrong with the block, there is a local shop who you can take it to and have fixed, also if you ever have any questions with the block they are right there. Another thing that's good is to witness the motor being assembled - making sure the specs are all correct etc.
just my .02
Old Jan 13, 2004 | 06:11 AM
Dyno Queen's Avatar
i decided to do it this way i have to sae a lil cash so thanks again for your advice,
later man
Old Jan 13, 2004 | 08:29 AM
allablur's Avatar
Default Re: (Dyno Queen)
good idea dyno id say save atleast 3k just incase, that way if u see something u like u can get t with no problems and if its cheaper than u got left over money for all the little extra stuff that surprised the hell out of me on my build up i.e. ignition fuel,etc... i knew i would spend some on that but it adds up really fast
Ls_dx
Oct 28, 2010 05:28 PM
ek9tl
May 11, 2007 02:50 PM
DarkTeg94
18
May 16, 2006 07:30 PM
fast93accord
Nov 17, 2004 01:43 PM
phiberoptik
Jun 5, 2003 10:50 AM
