The build...........................
Old Jan 1, 2004 | 08:45 PM
Bulldogg83's Avatar
Default The build....new pics added....
Alright so it's no secret to some that I am doing another turbo setup on my 00 Si. I had the Greddy TD05-18G turbo setup about 7 months ago, made 275whp/218ftlb of torque @ 13psi, and then sold it all.....thought I was going to get out of the game, but realized I missed it too much! So, I am starting another setup. The following link is only pics of the turbo b/c it's the most important thing, but my manifold and intercooler are supposed to be here in a few days and once they get in then I will take more pics....
http://f1.pg.photos.yahoo.com/...ision
Da Plans......
-b16a bored/honed 83mm
-Benson sleeves
-CP 9.1:1 or 10.1:1 Pistons (still needing some info then going to decide...)
-Pauter Rods
-ARP Head Studs
-b16a head that is going to be milled with a 5 angle valve job
-Hondata Intake Gasket
-GSR Cams
-Inline Pro Adjustable Cam Gears
-REV Springs and Retainers
-Ferrea Valves
-Precision GT35E Turbo A/R .60/ A/R .63
-Inline Pro Manifold
-Tial 38mm Wastegate w/ .7 bar Spring
-HKS SS BOV w/ 65mm flange
-Precision AS1026 Intercooler--"750hp"--31.5"x10.3"x3.5"
-Hondata s200b
-Hondata Chipped p28 ECU
-Precision 880 Injectors
-STR Fuel Rail
-AVCR Boost Controller
-Greddy 52mm Boost Gauge and EGT Gauge
-Greddy Oil Catch Can
-MSD 6a ignition
-Fluidyne Radiator
-Proform Electric 12" Slim Fan
-Gator Stage 2 Axles
-ACT Extreme w/ SS Disc
-Place Racing Rear Mount
-Energy Motor Mount Inserts
-3" Downpipe->Testpipe->2 Resinators->Dump
I have everything except for the built motor which is in the works and possibly a tranny swap.....but hopefully within the next two months everything will be complete and ready to go....more pics will be posted as I receive more parts through Fedex/UPS....
Modified by Bulldogg83 at 11:58 PM 1/1/2004
Modified by Bulldogg83 at 12:04 AM 1/2/2004
Modified by Bulldogg83 at 10:31 PM 1/2/2004
Modified by Bulldogg83 at 7:25 PM 1/3/2004
Modified by Bulldogg83 at 11:07 AM 1/6/2004
Old Jan 1, 2004 | 08:48 PM
-iLLuZioN-B18C1's Avatar
Default Re: The build........................... (Bulldogg83)
what are your hp goals?
set up looks nice
Old Jan 1, 2004 | 08:49 PM
1point5CRX's Avatar
i think everything looks good except your intercooler is alittle overkill,besides that everything is butter
Old Jan 1, 2004 | 08:51 PM
Bulldogg83's Avatar
Default Re: The build........................... (-iLLuZioN-B18C1)
Yes these are realistic numbers ....
I am wanting to try and shoot for 400-450whp on pump gas....that's why I am still debating on the compression ratio for the pistons. I am going to probably tune it to 325 whp daily driven and then for my scramble setting go for the higher numbers....
Old Jan 1, 2004 | 08:52 PM
Bulldogg83's Avatar
Default Re: The build........................... (1point5CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX &raquo;</TD></TR><TR><TD CLASS="quote">i think everything looks good except your intercooler is alittle overkill,besides that everything is butter </TD></TR></TABLE>
it was between the 750hp one or the 600hp one....got pricing for them and figured for $40 more might as well get the bigger one! It was like with my injectors there was a $5 difference between 720's or 880's....hmmmm No brainer there....
Old Jan 1, 2004 | 08:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">Yes these are realistic numbers ....
I am wanting to try and shoot for 400-450whp on pump gas....that's why I am still debating on the compression ratio for the pistons. I am going to probably tune it to 325 whp daily driven and then for my scramble setting go for the higher numbers....</TD></TR></TABLE>
i seee your already going to bore/hone, why not just throw in some sleeves since your already going all out
Old Jan 1, 2004 | 08:59 PM
Bulldogg83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
i seee your already going to bore/hone, why not just throw in some sleeves since your already going all out </TD></TR></TABLE>
****....new I forgot something (*edited description*)! Actually I am going to be using Benson sleeves...sending da block to good ol' Earl!
Old Jan 1, 2004 | 09:02 PM
now its a really nice set up, lol
i would personally go with the 9.1 and turn up the boost.
Bulldogg83's Avatar
just hope that 400-450whp is possible on 93 octane....
Old Jan 1, 2004 | 09:34 PM
FredoSP's Avatar
thats 95% like mine just crower rods, 84.5mm Rollerwaves and Supertech Valves/Springs/Retainers. I'll be hitting the dyno once she is dropped in next weekend.
Edit: 9.3:1 CR
Old Jan 1, 2004 | 09:54 PM
txhatch's Avatar
SOunds like a nice NA setup..... .
Old Jan 1, 2004 | 10:02 PM
Hoosier Daddy's Avatar
Sounds nice! Good luck
Old Jan 1, 2004 | 10:04 PM
Suprdave's Avatar
Default Re: The build........................... (Hoosier Daddy)
Kepe the CR low if you want max power on pump
Old Jan 2, 2004 | 06:33 AM
onetwothree's Avatar
Those are some awesome pics. What camara did you use?
Old Jan 2, 2004 | 06:43 AM
espanol's Avatar
looking good bullfrog!
Old Jan 2, 2004 | 07:56 AM
4U2NV's Avatar
Default Re: The build........................... (txhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txhatch &raquo;</TD></TR><TR><TD CLASS="quote">SOunds like a nice NA setup..... .</TD></TR></TABLE>
Hopefully it will yield better numbers than his N/A set-up...
Old Jan 2, 2004 | 09:57 AM
Bulldogg83's Avatar
Default Re: The build........................... (onetwothree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onetwothree &raquo;</TD></TR><TR><TD CLASS="quote">Those are some awesome pics. What camara did you use?</TD></TR></TABLE>
Nikon Coolpix 3100
Thanks for all the replies...hoping to make better power than what I have now...
Old Jan 2, 2004 | 11:48 AM
quikB18B's Avatar
Damn thats alot of $, but atleast it's being spent wisely.
Nice setup
Old Jan 2, 2004 | 11:56 AM
Bulldogg83's Avatar
Default Re: The build........................... (quikB18B)
thanks...it will hopefully all pay off in the end
Old Jan 2, 2004 | 12:05 PM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">thanks...it will hopefully all pay off in the end </TD></TR></TABLE>
you're such a baller!
Old Jan 2, 2004 | 12:07 PM
Bulldogg83's Avatar
Default Re: The build........................... (espanol)
espanol you are my hero!
Old Jan 2, 2004 | 12:19 PM
RacerSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">Alright so it's no secret to some that I am doing another turbo setup on my 00 Si. I had the Greddy TD05-18G turbo setup about 7 months ago, made 275whp/218ftlb of torque @ 13psi, and then sold it all.....thought I was going to get out of the game, but realized I missed it too much! So, I am starting another setup. The following link is only pics of the turbo b/c it's the most important thing, but my manifold and intercooler are supposed to be here in a few days and once they get in then I will take more pics....
Da Plans......
-Benson sleeves
-Pauter Rods
-ARP Head Studs
-GSR Cams
-Adjustable Cam Gears (still debating on which ones...)
-Ferrera Valves
-Hondata s200b
-STR Fuel Rail
-MSD 6a ignition
-Fluidyne Radiator
-3" Downpipe-&gt;Testpipe-&gt;2 Resinators-&gt;Dump
Modified by Bulldogg83 at 12:04 AM 1/2/2004</TD></TR></TABLE>
Damn your turbo setup is my dream setup
Old Jan 2, 2004 | 01:41 PM
AVATAR's Avatar
Default Re: The build........................... (RacerSi)
So much for the 300-350 build . . . . douche
Old Jan 2, 2004 | 02:51 PM
DIRep972's Avatar
Smarter than you
Nice set up playa!
big power on pump = go w/ low compression
Old Jan 2, 2004 | 03:32 PM
Bulldogg83's Avatar
Default Re: The build........................... (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">So much for the 300-350 build . . . . douche </TD></TR></TABLE>
