Dyno (blox manifold)
Old Nov 5, 2004 | 11:51 AM
XxRoCkMaNxNEOxX's Avatar
Default Finally Boosted (Dyno included w/ blox manifold)
TUNED BY ST00PID(Conservative 10psi)
Setup:
Stock b16
Blox manifold
Precision SC34 a/r .48
Tial Wastegate
Spoolin 2.5-3" dp (running open)
FMIC
Walboro 255lph
RC 550cc
Honda s100 w/ boost
Blitz bov
Modified by XxRoCkMaNxNEOxX at 12:20 AM 11/8/2004
Modified by XxRoCkMaNxNEOxX at 12:44 PM 11/8/2004
Modified by XxRoCkMaNxNEOxX at 10:29 PM 11/10/2004
Old Nov 5, 2004 | 11:56 AM
NotPhilTran's Avatar
Default Re: Dyno (XxRoCkMaNxNEOxX)
it seems a bit low.
my set up
b16a greddy d series manifold
greddy wastegate
15g turbo
hondata
233whp. 9 psi.
Old Nov 5, 2004 | 11:59 AM
Default Re: Dyno (NotPhilTran)
yeah ikno man my car just wasnt making the power. i dont know what happened
Old Nov 5, 2004 | 12:25 PM
714phil's Avatar
i made the same exact whp with a drag kit w/ pump and regulator @ 7psi on a completely stock b16a untuned. the AF of course was not that great.. 12:1 up top.
Old Nov 5, 2004 | 12:26 PM
Default Re: Dyno (STD ONEpointSIX)
damn neone no why i got no power? i kno everycar is different would the manifold have that big of a difference?
Old Nov 5, 2004 | 12:37 PM
antisport's Avatar
Manifolds are just a plus... you might be leaking boost some where, put the boost gage up past the blow off valve like use one of the lines up there? just a shot in the dark I mean not 100% possitive if what I am saying will help.
My friend has a prelude and got the pressure off the turbo and by the time it got to the trottle was around 7psi from 12psi at the wastegate spring, and then we found problem and he has better numbers! but if that is the case you might need fresh tune again
Old Nov 5, 2004 | 12:40 PM
95GSRTT
Guest
Posts: n/a
Default Re: Dyno (antisport)
I personally think that your low hp has nothing to do with that manifold. The design is just like inline pro, and ppl make great power on that. I think you need to look else where for the problem.
Old Nov 5, 2004 | 12:42 PM
Default Re: Dyno (95GSRTT)
where do i need to look? the turbo is brand new and also the manifold
Old Nov 5, 2004 | 12:44 PM
antisport's Avatar
youve posted your BOV sucks so maybe thats the problem boost might be leaking.
Old Nov 5, 2004 | 12:57 PM
Ri5e's Avatar
The torque is weak
95GSRTT
Guest
Posts: n/a
check compression, check boost leaks in bov/wg/couplings/gaskets. Thats what sux when you have a problem with a car. there are TONS of possibilities. But unless there is a crack in the manifold thats not the problem.
Old Nov 5, 2004 | 01:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by antisport &raquo;</TD></TR><TR><TD CLASS="quote">youve posted your BOV sucks so maybe thats the problem boost might be leaking.</TD></TR></TABLE>
it works now , i checked my compression b4 the install and it was
207 207 207 198
Old Nov 5, 2004 | 01:32 PM
Syner-G-Racing LLC's Avatar
check compression. and do a leak down.
Old Nov 5, 2004 | 02:17 PM
714phil's Avatar
Default Re: Dyno (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart &raquo;</TD></TR><TR><TD CLASS="quote">The torque is weak</TD></TR></TABLE>
no kidding its a 1.6
Old Nov 5, 2004 | 02:28 PM
No-Gi's Avatar
My friend just made 250 whp and 176 wTq on 9 Psi stock b16.
he only tuned with a VAFC so you should make more than him with S100
Old Nov 5, 2004 | 02:38 PM
uglyasscivic's Avatar
Its the .48 ar exhaust housing. Bolt on the .63 and it will free up some power for sure.
You should also check your wastegate dumptube. If you ar sucking in wasted exhaust gas from the wastegate you will lose a HUGE amount of power.
Old Nov 5, 2004 | 02:57 PM
turbo*s2k's Avatar
Default Re: Dyno (uglyasscivic)
It's a b16. I feel your pain... Look at the #'s in my sig... I should be putting down more power.
There's no replacement for displacement.
I used to have the sc34 and it didn't make good power on my setup. I was boosting 20 psi, and only making a little over 300whp. I switched to a full-race t3/t67 stage 3 wheel .62 a/r and made 330whp on 14 psi. The #'s are still a bit low in my opinion, but much better...
Old Nov 5, 2004 | 03:57 PM
Timmay's Avatar
Default Re: Dyno (TurboChrgd_Civic)
My buddy had the same turbo on his b16a3 del sol, he made 263 whp and 197 tq on 8.7 psi with hondata, tuned by cortney(uglyasscivic).
Old Nov 5, 2004 | 04:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">It's a b16. I feel your pain... Look at the #'s in my sig... I should be putting down more power.
i guess some cars are different eh. looks like u had the same situation.
Modified by XxRoCkMaNxNEOxX at 9:12 PM 11/5/2004
Old Nov 5, 2004 | 06:12 PM
i just did a comp test
200 200 200 200
Old Nov 5, 2004 | 06:32 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxRoCkMaNxNEOxX &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by XxRoCkMaNxNEOxX at 9:12 PM 11/5/2004</TD></TR></TABLE>
very true!
Old Nov 5, 2004 | 06:35 PM
jfoster's Avatar
I would think the BLOX mani would be so close to the inline pro in design that #s on otherwise equal machines would be the close to same...seems like the problem must be somewhere else....if there is a problem...
Old Nov 5, 2004 | 06:40 PM
Default Re: Dyno (jfoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster &raquo;</TD></TR><TR><TD CLASS="quote">I would think the BLOX mani would be so close to the inline pro in design that #s on otherwise equal machines would be the close to same...seems like the problem must be somewhere else....if there is a problem...</TD></TR></TABLE>
well the blox works great, it hold the boost really well w/ my turboxs manual controller and tial wastegate. i mean i just did a comp test and it looks healthy. i guess like i said b4 not every car is the same or motor.
Old Nov 5, 2004 | 08:35 PM
TEZTnTUNE's Avatar
hmm whats your max timing at? what engine management are you using? im to lazy to scroll up? any a/f charts? what heatrange on plugs? what octane? what compression? more info please
Old Nov 5, 2004 | 08:49 PM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">i made the same exact whp with a drag kit w/ pump and regulator @ 7psi on a completely stock b16a untuned. the AF of course was not that great.. 12:1 up top.</TD></TR></TABLE>
What's wrong with a 12.1 AFR? Most tuners would shoot for that...
