****CEL CODES PLEASE HELP!
Old Nov 4, 2004 | 01:11 PM
b00sted_GS-R's Avatar
Default ****CEL CODES PLEASE HELP!
Okay, here the problem every time I get on it, around 5k rpm it throws a cel and after that it wont let me go past 3000 rpm. I tried to run to autozone and check it but the hondata keeps delete the dam code. So I tried checking it my self. I got 2 long blinks and 1 fast, then a long long pause 1 long blink and 6 shorts. then CEL keep blinking in the same pattern. I got 16 and 21, but im not positive. what codes are they and what can I do to fix the problems thanks mike
Old Nov 4, 2004 | 01:30 PM
Bulldogg83's Avatar
Default Re: ****CEL CODES PLEASE HELP! (b00sted_GS-R)
Check out this site:
http://www.c-speedracing.com/faq/05.php
Old Nov 6, 2004 | 10:10 AM
Default Re: ****CEL CODES PLEASE HELP! (Bulldogg83)
I Dont know what to do, I checked all my wiring its still intach, and ohm it to check for breakage still fine. What else can i check?
Old Nov 9, 2004 | 10:11 PM
BUMP for the nite...still need help...
Old Nov 10, 2004 | 01:18 AM
FredoSP's Avatar
sounds like the car goes into limp mode (can't rev past 3k)
Any vac leaks, could it be your idle Air control valve?
slowesteg
May 11, 2012 11:07 PM
91ef_civic
Mar 22, 2011 02:33 PM
phatdroid06
Apr 16, 2009 08:26 PM
HONDRETTI
May 6, 2008 09:38 AM
beeroh
Sep 24, 2004 08:16 AM
