is it my valves ?
Old Nov 3, 2004 | 10:08 PM
Go Fast Civic's Avatar
Default Is It My Valves ?
i noticed a loud rattling/tapping noise that sounded like my lifters or valves got raped only when i tap the gas, not hold it in. there was oil all over my intake mani due to oil comming out of the valve cover vent.
The engine <U>still runs</U>. what do you guys think the problem might be?
Modified by gofastcivic W at 6:40 PM 11/16/2004
Modified by sportinemotions at 8:56 AM 11/17/2004
Old Nov 3, 2004 | 11:27 PM
oneforce's Avatar
Default Re: Is It My Valves ? (gofastcivic W)
i had the same problem with my 96 coupe man... i first thought it was my belt tensioner or waterpump, opened the whole thing up....wasnt the problem...i then adjusted my valves, they stopped tapping, but my ride runs shitty now.... i gave up...
Old Nov 3, 2004 | 11:49 PM
CRX_1.8T's Avatar
have you pulled the valve cover off yet and investigated?
Old Nov 4, 2004 | 04:47 AM
im going to pull the valve cover off today and do a compression check, and see if anything seems broke, i just want to know what kinda things to expect with these symptoms.
i dont think my valves are out of adjustment... there is definatly something else wrong.
Old Nov 4, 2004 | 11:31 AM
Bump
Old Nov 4, 2004 | 12:29 PM
Louie_EM1
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gofastcivic W &raquo;</TD></TR><TR><TD CLASS="quote">nevermind i went outside to and started it up just now and kineechywah bitches it runs fine w00t i think what happened was i was taking it to high rpms and my lifter might have collapsed because of loss of oil to the head, hence all the oil all over my intake mani. When sittin over night the cam must have been in the right position so that the rocker was off of the lifter and it let the lifter build it self back up. nice</TD></TR></TABLE>
yeah.... I sometimes make problems seem like nothing too.
Do a compression test first thing.
Old Nov 4, 2004 | 12:30 PM
EGJdmJreams's Avatar
RINGS RINGS RINGS
like a telephone
Old Nov 4, 2004 | 12:38 PM
Louie_EM1
Guest
Posts: n/a
Default Re: (EGJdmJreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGJdmJreams &raquo;</TD></TR><TR><TD CLASS="quote">RINGS RINGS RINGS
like a telephone</TD></TR></TABLE>
or...
like a champsionship RING
or a wedding RING
or a circus RING
Old Nov 4, 2004 | 12:53 PM
Default Re: Is It My Valves ? (Louie_EM1)
its still the same problem compression test showed 150-150-150-80
didnt tap for some rason until i drove it around the block
Old Nov 4, 2004 | 12:58 PM
BauleyCivic's Avatar
Risky Business
Ringland #4 is probably gone, or bent valve
Old Nov 4, 2004 | 02:06 PM
Default Re: Is It My Valves ? (BauleyCivic)
Gotta be the valves since the horrible tapping noise
Old Nov 4, 2004 | 02:18 PM
SOHC_MShue's Avatar
yea that cylinder is fucked. Definantely something going on.
Old Nov 4, 2004 | 04:00 PM
Bserieskllr's Avatar
looks like its time to pull the head off.
Old Nov 4, 2004 | 04:57 PM
Default Re: (Bserieskllr)
well thanks guys ! im going to pull the head off tomarrow afternoon. I'll keep you guys posted
Old Nov 4, 2004 | 06:16 PM
slambedcivic's Avatar
Default Re: (gofastcivic W)
9psi + 310s + FMU = bad....
always play it safe with fuel.
Old Nov 4, 2004 | 07:54 PM
Default Re: (slambedcivic)
definatly learned my lession here today... im still deciding between hondata and uberdata
Old Nov 4, 2004 | 07:55 PM
Risky Business
The stock fuel pump was probably maxed out...
uberdata
Old Nov 5, 2004 | 02:14 PM
took valve cover off... pushed donw on the tops off the rocker arms and all but 2 intake valves moved. so i pulled the head off and i guess im going to have to send it to a machine shop for a valve job
Old Nov 5, 2004 | 05:01 PM
what head gasket do you guys recomend ?? what should i torque it to 60 - 65 ?
Old Nov 6, 2004 | 05:09 AM
cometis makes great head gaskets. @ only 9lbs of boost, im still running a oem honda gasket.
you can always check out felpro gaskets, they have this MLS (multi layer steel) gasket, and they are great as well
Old Nov 9, 2004 | 06:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">took valve cover off... pushed donw on the tops off the rocker arms and all but 2 intake valves moved</TD></TR></TABLE>
Bump for a little help with that. Could it also be the lifters or what ?
Thanks for the help my head is at the machine shop for a valve job. Not sure if i would need to fix anything else while its there. I'm kind of in a hurry.
Old Nov 9, 2004 | 09:44 PM
bump
Old Nov 10, 2004 | 09:41 AM
UP
Old Nov 10, 2004 | 10:27 AM
ok the machine shop that is fixing my head said that there is NO bent valves ?? what the hell else can make it tap like that ?? colapsed lifter or what ?
Dav94Lx
Oct 9, 2007 07:53 PM
Hondapreludeg
Aug 2, 2007 02:27 AM
Hemix
12
Jul 15, 2007 01:20 PM
user 98292739
Apr 17, 2005 08:22 PM
rlj51
Apr 9, 2003 01:48 PM
