d-serise greddy manifold
Old Nov 3, 2004 | 03:09 PM
RACEPAK's Avatar
Default d-serise greddy manifold
hello everybody
is it possible that a greddy manifold will crack?
is it fixable ?
best regards moshik galimidi
Old Nov 4, 2004 | 05:20 AM
RACEPAK's Avatar
Default Re: d-serise greddy manifold (RACEPAK)
PLEASE HELP
Old Nov 4, 2004 | 06:25 AM
USDM 4G VTEC's Avatar
if cracked, yes it can be fixed
buts is a long process
the manifold needs to bea heated and maintain there for like 20 minutes
weld while it hot
, mantain the temperature, and after welded, during the next 12 hrs, slowly decrease the temp until is all good
Old Nov 6, 2004 | 02:01 PM
RACEPAK's Avatar
Default Re: (USDM 4G VTEC)
have you ever seen a cracked greddy manifold?
Old Nov 6, 2004 | 04:43 PM
please.laugh's Avatar
Does it really need to be heated for 12 hours? The only reason the cast cools at a different speed is because of the air bubbles, right? I've seen a local welder weld a cast manifolds (mine) with a furnace and a torch. He heated the manifold up really hot, pulled it out, welded it it really quick and tossed it back in the furnace, then let it cool down in the furnace. Didn't take 12 hours. The weld worked
dewoine
Jan 30, 2009 01:13 PM
PA MATT
Aug 2, 2004 10:11 AM
Tetronious
Jun 30, 2004 07:39 PM
b18c5turbo
May 3, 2002 07:39 AM
