AFC not working. searched!
Old Nov 5, 2004 | 06:51 PM
Curtis2kul's Avatar
Default AFC not working. searched!
my vafc is not changing the amount of fuel my car is getting, its not reading any rpms at all. I know i have the right wire for the rpm signal because i ran a wire from the tach to the green wire to make sure i had the right signal. Anyone had this problem before? is there any reason why the afc is not getting a rpm signal?
Old Nov 5, 2004 | 07:01 PM
MooreBoost's Avatar
Default Re: AFC not working. searched! (Curtis2kul)
Go to the voltage check feature and make sure its getting a signal.
Old Nov 5, 2004 | 07:05 PM
Curtis2kul's Avatar
Default Re: AFC not working. searched! (tegunderpressure)
its not reading any rpm signal when the car is running but i dont see why it couldnt because the rpm wire is ran straight into with my tach
Old Nov 6, 2004 | 03:08 AM
Curtis2kul's Avatar
Why are there 2 grounds on the afc do you think one of them has a bad connection?
Old Nov 6, 2004 | 08:48 AM
MooreBoost's Avatar
Make sure you are using the ECU ground wire to ground the AFC, instead of just running a screw into the firewall. Go back over you connections and solder and heat shrink them, it sounds like your wiring in general is causing you problems.
Old Nov 6, 2004 | 03:08 PM
shrug's Avatar
make sure you have the brown tapped closest to the ecu, then the black about an inch behind that.
also, you should tap the green rpm signal wire into the wire from the ecu, not to your tach.
Old Nov 6, 2004 | 04:31 PM
Curtis2kul's Avatar
Default Re: (shrug)
the grounds are right its just like 2"'s apart. but i dont think that makes a big deal. and with the rpm, its getting the same signal at the tach so why not just run it off that if i cant find the tach wire on the computer
Old Nov 6, 2004 | 07:45 PM
BDTURBO's Avatar
Default Re: (Curtis2kul)
Im having the same problem...Im almost definite its my wiring!
Old Nov 7, 2004 | 11:12 AM
shrug's Avatar
because maybe its a stronger or different signal, you never know. this is what we call troubleshooting.
averyvm
Jul 15, 2008 07:34 PM
dc2leftovers
Dec 30, 2007 11:26 PM
civiclxb16a
Apr 30, 2005 09:37 PM
Hyaboosta
Jan 11, 2005 05:48 PM
