Help: Motor Shuts Off When Hot
Old Nov 8, 2004 | 02:44 AM
MR BLACK RAG's Avatar
Default Help: Motor Shuts Off When Hot
Hi everyone im posting this for a friend of mine his car is boosted and it turns off when it gets hot. it doesnt happen all the time but it happens pretty much. it happens mostly during the day time does anyone know how we can fix this? im not sure of his exact set up but i know it is
B18C1 JG Sleeved 84.5MM
Fully Ported PR3 head with gsr cams
60-1
AEM EMS
ill find out his exact setup and ill post it
Old Nov 8, 2004 | 04:22 AM
anyone?
Old Nov 8, 2004 | 07:57 AM
PrecisionH23a's Avatar
Default Re: Help: Motor Shuts Off When Hot (MR BLACK RAG)
Did you try messing with the idle % vs target idle?
If not, set idle% vs target so that at each breakpoint the idle learned is about -2 to -4%.
Old Nov 8, 2004 | 08:09 AM
salt's Avatar
I think mine is doing this too. I also have the AEM and I'll be driving on the highway, and the engine just dies. If I turn the car off and wait a minute it will start again. I recently switched from .94 to 1.11 and I also switched from MSD back to stock ignition. I checked the coil dwell and it is set to 40, which is set for the stock coil. When I had the MSD and V94 I never had a problem. I'm going to install the C2DI and hope that that helps. I'll let you know.
Steve
Old Nov 8, 2004 | 02:25 PM
bump
Old Nov 8, 2004 | 08:16 PM
Default Re: (MR BLACK RAG)
no one else?
ernesto.labucay
Honda Civic (2006 - 2015)
May 14, 2016 06:13 PM
supersilverdc2
Jun 2, 2014 05:56 PM
darkstar1440
Aug 1, 2006 07:58 PM
greaseball
May 5, 2004 03:54 PM
Que_Lude
Jan 23, 2003 01:12 PM
